Chris NottAH Fabrications
Results 1 to 7 of 7
    Felon's Avatar
    Slightly odd.
    Oct 2007
    Chandler's Ford, Hampshire
    87
    Intermittent turbo?
    Ok - like a good boy I have read the FAQs and done a search but none seem to describe what I experienced this morning.
    Drove off from cold and it was clear I was driving a normally aspirated 1.8. No drama, no fuss, no turbo.
    Got to where I was going about 5 miles away and left the car for 5 minutes - got back in and hey presto; plenty of turbo.
    From reading the aforementioned FAQs and search results this could be due to a number of things but nowhere did I read that it comes and goes like it did with me.
    Anyone got any ideas or is it a trip to my local Mr Audi to plug in his vag...?
    Ta!
    2002 Absolute Red (Tomato Soup colour) S3 Custom Code Phase 1 done 10th October 2007
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    it sounds like the car is going into limp mode - it basically stops using the turbo and makes the engine produce "limited" power to reduce any potential damage to the engine, unfortunately without a vag.com scan it's hard to say why - are there any members near you that could scan it for free? - i'm based in surrey but that might be a bit too far for you to travel
    Mike
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    Felon's Avatar
    Slightly odd.
    Oct 2007
    87
    Appreciate the offer - thanks!
    My S3 is under warranty so presumably even Audi would not charge me for having a quick look with Vag.com??
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    yes - i think you should be ok if it's under warranty
    S3 AMK
    Jul 2005
    2,488
    if they play by the letter, then only parts and labour are covered by the warranty. Diagnostics, or time taken to diagnose a problem are not covered.
    I've never been charged for any of the above on any warranty claims though.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    I'm going to go out on a limb and guess that your MAF sensor is at fault.
    Felon's Avatar
    Slightly odd.
    Oct 2007
    87
    Thanks chaps - will take it down to Southampton Audi and see what they say.
