EM TuningAH Fabrications
Results 1 to 11 of 11
    Jul 2004
    Reading
    81
    S3 creaking suspension over speed bumps
    Hello All.
    My 2002 S3 has the habit of creaking as I drive over speed ramps (if I drive slowly) I'd say it's coming from the front and doing a search on this list it sounds like it might be an anti roll bar. So my quesitions are as follows....
    1. I've read you can spray the ARB to see if this is causing the creak, can someone give some instructions on where to find it and what it looks like.
    2. if this is the issue how much can I get another one fitted for?
    Brian
    Feb 2004
    2,036
    oil is a good test but the bar is sleeved together an d is proibly knacked now!
    BUT be careful make sure it is the front, if its the rear it could be the rear arm bushes seizing up,the next thing will be rear arm failure and possible instant death!
    Shifty's Avatar
    Avvve it!
    Oct 2007
    wales
    47
    prob the bushes, their cheap but a ******* to do, even then u may get a creak...ive just come to live with the creak, tho recently i plastered them with spray grease and they have quietened down COSIDERABLY, u can see em if u full lock the wheels, however if u can whip the wheels off will see em, they are attached to a tube like bar running across the car, hard to explain, rubbers are pretty small
    Nov 2007
    I actually have the same problem with my s3. I'm going to be taking a look at it this weekend, i'll give the bushes a good coating in grease, and spray the anti roll bar. The cold is probably starting to make the noise sound worse now as the rubber will be harder in the colder weather...
    Good luck with yours, i'll let you know how I get on at the weekend!!
    Shifty's Avatar
    Avvve it!
    Oct 2007
    wales
    47
    dont use oil based lubricant like wd40 this will knacker the rubber in the long run, good spray grease will do job
    Nov 2007
    Surrey
    same thing with mine.
    Qst replaced the bushes & the bar problem solved
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    brake fluid works well on bushes.
    but back to the ARB the sleves nearly always crack on the ARB. If you havn`t read before the std S3 ARB is sleved up to a thicker size for the ARB bush. The R32 one are thicker and hence no sleve. This is the main reason for Fitting R32 ones to my S3.
    Some ppl like em some ppl dont. I think the R32 one are ok..
    red to red black to black blue to bits
    Nov 2007
    Just used the wonders of spray grease on my suspension, and fingers crossed it has sorted the creaking noise I was experiencing. I've taken the car out for a test drive and couldn't hear any creaking, I'm hoping this has solved the problem, Go out and get the miracle that is spray grease!! only cost 5 - a hell of a lot cheaper than replacing the bushes!!
    Jul 2004
    Reading
    81
    well as an aside my car failed its MOT last week on the drivers side track rod end (too much play) after this was replaced my creak has gone, so be ware this creak may be worn track rods as well as the ARB bushes.
    Brian
    jcb
    Sep 2005
    uk
    4,077
    [QUOTE=fingermouse]brake fluid works well on bushes.
    QUOTE]
    I won;t be spaying a known corrosive substance and irritant around the outside of my car.
    Apart from it's ability to strip paint, it is not something I really want to rubbing all over me every time I get under the car to change/fix something
    Dec 2006
    84
    Use a silicone grease - abotu £4 from halfords.
    Changing the front ARB's is nto very difficult, bust as many people have said the sleeves on the ARB itself split & crack so while new bushes might quietent things down, it might not cure the problem entirely.
