JMB RetrofitsBadger5
    Jun 2007
    i cant believe it....
    ill try to keep this as short as possible but i had this annoying problem with my car recently where it was very hesitant and gradual in accelerating and after every gear change, the car would jerk a little.. and when running at idle speeds, the engine was not constantly smooth at tick over, there were occassional jerks.
    Anyway that engine packed up on me recently and i have just got it replaced and to my horror... im getting the same problem again!!
    any ideas people?? as now im like..
    recent work other than a replacement engine is complete service inc spark plugs, new cambelt kit inc tensioner, new water pump. new thermostat,new clutch, new water temp sensor, new abs sensors and a new MAF!
    Feb 2004
    2,036
    Fuel pump or filter blocked?
    what bits were swapped over from the other engine? Could be any of the many sensors or ancilliaries, MAF sensor maybe duff, was it genuine?
    Try the IAT inlet air temp sensor too, clean it or renew it.
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    Lambda maybe?
    needs scanning with a diagnostic tool really to see what fault codes it throws back other than that we're only speculating
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    When you got the engine replaced did you get a new throttle body or use the old one?? as i had a similar issue that went on for ages till i got a new throttle body then all was good.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Shifty's Avatar
    Avvve it!
    Oct 2007
    wales
    47
    ignition coils?
