    S3 amd map,coilovers,upgraded heldex,lcr spliter..
    Apr 2007
    Bristol
    228
    electric seat problem
    i have bought some black leather to replace my grey but the drivers seat will only adjust on the tilt the whole seat button and not on the lumber or just the back. any idea how many motors are in the seat as i can only see one. i have chanced the two relays on the bottom, are there any ive missed? any fuses?.
    thanks
    Apr 2007
    Bristol
    228
    bump
    A3steve's Avatar
    Sep 2006
    126
    S3 recaro motors - per seat
    V28 Longitudinal adjustment motor
    V29 Front height adjustment motor
    V30 Seat rear height adjustment motor
    V45 Backrest adjustment motor
    V125 Lumbar support longitudinal adjustment motor,
    also seat adjustment fuse S45 30A
    Regards Steve
    Apr 2007
    Bristol
    228
    thanks steve, i think i need to see if the powers getting to the motors and its not the switch/ fuse ect. there a pain to get into.
    A3steve's Avatar
    Sep 2006
    126
    I'd also check that the 12v negative is ok too (Brown wire)
    Apr 2007
    Bristol
    228
    if the 12v neg is playing up would any of the motors work? one works ok!
