EM TuningMonster Motorsport
Thread: DV Servicing??
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    DV Servicing??
    Just interested if I should service/ replace my DV. I've had a hyperboost on the car for nearly a year without any problems. As I'm not technically minded I didn't know whether they are a consumable. Can they be serviced? It looks litke a sealed unit.
    Cheers.
    jesters3's Avatar
    The Shire's
    1,516
    Maintenance of Diverter Valve.
    1. Obtain service kit from AMD.
    Contains:
    Revised Spring. (stronger 2.5mm wire instead of 2.2mm)
    Sachet of grease
    6 new cap head (Allen key) screws
    3 O-rings :
    Lid 46mm x 1mm
    Body 43mm x 2mm
    Piston 40mm x 2mm
    2. Remove DV from vehicle.
    3. Remove 6 screws and dismantle. Lid will try and separate when you undo screws as the spring is beneath it.
    4. Once dismantled it should look like this:
    5. Clean Out DV. Removing old O-rings x 3.
    1 where lid seals,
    1 on piston
    1 inside the bore of the DV body.
    6. Here is the old spring compared to the new one. Same height dimensions and coils, just stronger wire, for more spring force:
    7. Replace O rings with new, lubricate bore, O -rings and piston with supplied grease and reassemble with new spring:
    All courtesy of PaulS3.
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    jesters3's Avatar
    The Shire's
    1,516
    Sorry pictures didn't come across. I've uploaded to rapidshare for download
    Jester
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    Cheers Jester but I'm sure mine is sealed so cannot be serviced. I think a new one is in order just to be on safe side. Its done nearly 13,000 miles.
