AH FabricationsEM Tuning
    Craigybaby37_A3quattro's Avatar
    Feb 2007
    141
    fitting forge 007p is it much of a job to fit??
    will be buying a forge 007p in the next week and just fort ide ask if there is anything else to fitting them than simply removing the 3 hoses from the standard 1 and fitting them to the 007p???
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,210
    As you've said, remove the three hoses from the old one and take it out then connect the three hoses to the 007P in the same way and it's fitted. Simple.
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,844
    Quote Originally Posted by Craigybaby37_A3quattro
    It's as DPM said, remove 3 hoses and reconnect, but the hardest bit is getting the factory hose clamps off, you need to have a decent set of cutters for the job, then a strong pair of hands to cut the buggers! Now replace them with normal screw type hose clamps and the rest is downhill...
    You've got to have a laugh!
