Badger5AH Fabrications
    S3 Dave's Avatar
    Now running on Heavy Oil
    Jul 2007
    Middle England
    432
    Coolant loss changing Thermostat?????
    I have concluded its my Thermostat that's tired after a few days and using A/c No.49. Digital display and Temp gauge are there or there abouts so sender must be OK. Going to change it at the weekend all being well. How much coolant will I loose???? Should a litre of G12 be enough??? The coolant was changed only about a year ago so not going to flush it out!
    Paid just over 15 for stat and O ring, numbers if anyone needs them..........
    038 121 119 B Washer/ O-ring
    050 121 113 C Thermostat
    "Never in the field of human conflict was so much owed by so many to so few"
    Churchill August 20th 1940
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Wheres the stat on the S3, simple to get to ?
    jbkudos's Avatar
    Jul 2007
    85
    where did you get the parts from I need to change mine
    2000 1.8TS "best in class"
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    Open the collant bottle to depressurise the system completely and close it, there will be some loss of coolant, but 1 litre should be fine i guess
    Quote Originally Posted by jbkudos
    vagparts...or your local dealer
    S3 Dave's Avatar
    Jul 2007
    Middle England
    432
    See previous posts for stat position. Its left hand side of block by alternator. Got the parts from local VW dealer. Will get some G12 when i collect the parts!
