Sky InsuranceAH Fabrications
    Sep 2006
    South East London
    58
    facelift lights + prefacelift wiring...
    got some facelifts from the bay arriving on friday.
    just wanted to find out if they can be fitted by cutting the wing and using the existing wiring, as i havent seen this mentioned in other threads.
    i will be taking this to a bodyshop as opposed to DIY btw.
    thanks in advance.
    Dec 2006
    190
    Well the plug on the new headlight is different to the origional plug so you will definately need to modify some of the wiring. you dont nessiserily have to cut the old plug off though, if you look through some of the threads im sure it has been covered before.
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    read here:
    headlight upgrade, is this the right choice...?
    all covered in. just follow the instructions clearly and shouldn't be a problem.
