Results 1 to 29 of 29
    Meza's Avatar
    Jul 2007
    Northampton
    99
    Toasted brakes? Help!
    Evening guys, I need your help please!
    I did a hefty stop in my S3 tonight, and got the usual massive fade afterwards, but now it feels like my brakes are completely shot.
    There is now next to no breaking force at all, and the pedal travels nearly to the floor. Only right at the bottom of the pedal is there a small amount of breaking force. The ESP light came on, went off after an engine restart and then came back on a minute later. I don't feel safe at all driving the car.
    What has happened, and more importantly what can I do?
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    Or maybe even your brakes!
    Sorry, thats not very helpful!
    J
    nky_84's Avatar
    Oct 2005
    Edinburgh
    431
    fluid has boiled and left lots of bubbles of air in the system perhaps?
    Could change the fluid an see if that improves things?
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    Maybe upgrade your brake fluid too, a few people on have said that helps reduce brake fade as well! Motul I believe..
    J
    Feb 2004
    2,036
    Unlikely, the fluid would cool pretty quick, and if its boiled fluid you would have pedal to the floor with no resistance . Fade is fade, ie a general pedal with no or reduced braking force. Pads could be knackered, or just poor pads.
    Are your brakes stock?
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    My suggestion
    Meza's Avatar
    Jul 2007
    Northampton
    99
    Quote Originally Posted by Jampublic
    Aarh what a fcukwitted mistake, I'm normally such a stickler for spag! Ok I was a little frantic when I posted, and the brakes were broken, breaked and brocked, all at the same time!
    Meza's Avatar
    Jul 2007
    Northampton
    99
    Yep brakes are stock, pedal just sinks to the floor at the moment. Once the fluid has boiled, will it return to normal after cooling it is bleeding/replacing it the only option?
    Is there anything that I could upgrade to between the stock S3 brakes and the brembo kit?
    What could I get for say £250 in the way of solid stopping power.
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    New disc's and pads maybe £300, black diamond grooved disc's and Ferodo DS2500's is nice little set up! Have a google and see what comes up, I think I found some good prices on Venom Motorsport last time I was looking.
    Good luck!
    J
    Meza's Avatar
    Jul 2007
    Northampton
    99
    What will the size of the discs on my S3 be please, are they 312mm or 288?
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Quote Originally Posted by Meza
    S3 standard front discs are 312mm by 25mm discs
    about 35 per disc from ebc brakes : http://www.ebcbrakesdirect.com/car/p...2898%2D2003%29
    Did the brake light come on at all? - it looks like this - (o), if it did, it would indicate your pads are low but it's never 100% accurate IMO.
    best bet would be to have the wheels off and see how much meat you have left on the pads and discs before buying new ones, from what you've described it could be air in the system as suggested above or possibly a leak somewhere.
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    Meza's Avatar
    Jul 2007
    Northampton
    99
    Nope I didn't get the brake warning, just the ESP light stuck on. Will stick it on vagcom tomorrow and see what that says.
    I thought it might be a good time to upgrade the discs and pads really if I'm going to need to flush the fluid anyhow. Those blackdiamond discs and Ferrodo pads seem to be getting good reviews on this forum.
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    thats what i'll be going to next i think - don't have the spare 's for brembo's just yet and i'm too wary to buy them off ebay or the like
    S3 AMK
    Feb 2004
    2,036
    What could I get for say 250 in the way of solid stopping power.
    the fluid should cool to give a pedal pdq, but once bolied, it loses some of its properties meaning its worth relacing at some point.
    it sounds to me like you may have a leak somewhere, if once cool the pedal still sinks to the floor. get it towed and checked. Depending on model and age, there was a fault with some VAG cars where the banjo washers on the rear brake line connections rotted through and caused total brake loss, but most have been recalled and replaced now. Worth havign a look under the rear just in case you see some leaks, it can happen after a very heavy appllication of the brakes.
    Feb 2004
    2,036
    Also if your ESP light is on, it could be you have a faulty wheel sensor on the abs which is meaning the brakes are releasing themsleves thinking the wheel is always locked! Its a scary fault and happended to me once on my golf.
    Try removing the fuses on the battery for the abs relay and abs pump. This will take the abs out of the system completely and if your brakes are suddenly back, it means there is a fault ono the abs system, ussually a wheels sensor melted! Vagcome will tell you which, about £80 each though! ! ngthe mcertheareew
    rodenal's Avatar
    Oct 2006
    1,982
    £80 for a sensor where did you buy that from??????
    £17.50e from eurocarparts
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    rodenal's Avatar
    Oct 2006
    1,982
    GSF even
    Feb 2004
    2,036
    Audi
    nky_84's Avatar
    Oct 2005
    Edinburgh
    431
    Quote Originally Posted by simch
    Try removing the fuses on the battery for the abs relay and abs pump. This will take the abs out of the system completely and if your brakes are suddenly back, it means there is a fault ono the abs system, ussually a wheels sensor melted! Vagcome will tell you which, about 80 each though! ! ngthe mcertheareew
    Simch, think i remember seeing a thread that you have done a few track days in your S3, have you taken the fuse out for them? I find the ABS kicks in way too early on almost every car ive driven. ABS is all good for preventing a huge lock up when a driver slams on the brakes in a crisis, but when your pushing on and wanting to squeeze every last % out of the S3's brakes i would of thought removing the ABS would improve the brakes performance on track, no? Also, does removing the fuse take out any other features?
    rodenal's Avatar
    Oct 2006
    1,982
    On an S3 i think puling the ABS fuse will take out your ESP too, could be wrong tho
    Feb 2004
    2,036
    I take it out when I take my old AGU golf on track but actually left it all live on the S3. Turn ESP off of course on track, but I found the ABS was fine. I think it depends on the grip you have as to when it will lock up and kick in, I found with my toyo rs and billy's , I was able to brake very late indeed, with the only concern being my bolied fluid at the combe, (now fixed with castrol srf installed).
    Meza's Avatar
    Jul 2007
    Northampton
    99
    The fault code tripping the ESP light was implausible signal from brake pressure sensor.
    I tried the brakes again today and they are no different. Soon into driving the whole DIS turned into a brake symbol with an exclamation mark in and it began beeping. Sounds like there must be a leak and I've now lost enough fluid for it to detect it.
    In the manual it says the pedal travelling to the floor may mean one of the circuits has gone.
    Where is the fluid reservoir - is it on the left hand side of the engine bay tucked under the strut brace? It looks really hard to get to.
    Meza's Avatar
    Jul 2007
    Northampton
    99
    I've just got the car back from the garage all fixed.
    One of the pipes going from master cylinder to ABS unit had burst. Apparently it was rubbing on a turbo pipe. They replaced this and all's fine.
    What I'm not happy about is the overpowering smell of jeyes fluid in the car, and a suspicious mark on the passenger seat!
    I haven't paid them yet, so I'm going to take a good look and sniff of the interior tomorrow and see if they've been putting oily boots all over my lovely banana seats.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    Thought it would be unlikely to be boiled fluid, one stop wouldn't generate enough heat to boil the fluid.
    Make sure when the pipe burst it didn't spray fluid all over the place as it removes paint really effectively.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Meza's Avatar
    Jul 2007
    Northampton
    99
    Good point, I'll ask them.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    I take it your car is fairly new?
    if it is and the pipe has burst then I'd kick up a ****ing stink, you could have been seriously injured, you expect the braking system to work, if it has removed any paint then get Audi to rectify it!
    Chris
    See my images @
  28. #27
    Meza's Avatar
    Jul 2007
    Northampton
    99
    I recently bought it from an independant garage, it's 2001 with 70k. It has a 12 month aftermarket warranty, but they said they wouldn't cover it as it's pipework - only cover mechanical items.
    It was a different independant garage that did the repair work.
    Do you think I have a case, who needs complaining to?!
  29. #28
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    Does the warranty paperwork actually state no pipework? How do they define mechanical items, as things that move? Sounds like a ******** get-out to me.
    I'd speak to the office of fair trading as this sounds like a dangerous negligence to me, or maybe VOSA might be a good place to start.
    Chris
    See my images @
  30. #29
    Feb 2004
    2,036
    Sounds like the pipework was moving, hence it touched th turbo and rubbed through!
    Aftermarket warranties are hopeless, waste of money IMO.
    As for the pipe touching the turbo, I have heard of this and was a real issue on some of the aftermarket turbo conversions too. One drafty veriosn in particular!! It is horrifying that you could lose all brakes from high speed.
    I think there was a post about something like this after a cambelt change where the garage moved a pipe out the way and forgot to put it back too. Not so long ago IIRC.
