Chris NottAH Fabrications
    Oct 2007
    Tips on wiper scratches on windscreen
    Okay on the M6 at the weekend, travelling at 'reasonable' velocity.
    (Would be points on my licence not a number of breakfasts at Her Majesty's pleasure)
    Some dirty crep on the windscreen, I wash-wipe......
    Wipers go feckin crazy, arms mix up and the driver side went under passenger, (It's off to the hard shoulder for us, yes they were aero spec). VW dealer has reset the arms this morning.
    I notice the scratches on the screen, nothing major but in the sunset going home tonight, pissang me off.
    Can autoglass miracle something up.
    May 2003
    Reading
    705
    Depending on how bad they are you could try Halfords Glass Cutter, I think that is supposed to remove small scratches, maybe worth a try for a fiver.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Halfords glass cutter? anyone used this?
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    steve
    Sep 2007
    Elgin, Morayshire
    81
    polish
    Personally i wouldnt use a glass cutter as this will remove the laminate from the windscreen, making it more prone to damage from stones when driving. Try using a filler polish, the only product i can think off of hand is the stuff you see for sale for removing scratces from your mobile phone display. I have used some polish when removing scratches from aircraft canopys at work that woked well. Ill see if i can lay my hands on some when im back to work in February
    steve
    Sep 2007
    Elgin, Morayshire
    81
    Should have read that last reply before posting it i look a little dislexic now!!!!
    Feb 2004
    2,036
    Quote Originally Posted by S3 ROCKS
    The laminate is the piece in the middle of the screen, its like two think sheets of glass sandwiching a flexible laminate. So I dont see how using some cutting compound will hurt the laminate unless you polish all the way through the first layer of glass...? You acrylic plastic polishes will not touch glass at all.
    To the original poster, what caused the scratches.....? Are the aero wipers not all rubber, (mine are)? Did one fall off and the arms scrape the screen...?
    If they are conspicuous and deep enough to catch your finger nail on, I think you will need a new screen. Should get one on insurance for 60 excess for accidental damage.
