Chris NottJMB Retrofits
    Oct 2007
    42
    s3 wastegate problem
    Hello there,ive got a problem with the wastegate bypass valve on my 2001 s3 not working properly ive brought a few new ones but no joy .its not boosting properly so got it looked at and they said that is the problem.can anybody help please??
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,427
    Do you mean Dump Valve(DV) when you say wastegate? If so, you need a re-circulating as opposed to a blow off one used on Jap cars, or the car won't run properly.
    Oct 2007
    42
    a garage put it on the computer and the fault said wastegate bypass vavle malfunction.i have have had 2 new standard dump valves and now ive got a baileys re-circulating 1.
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    might be your wastegate actuator is stuck if theres no boost at all, just stops the turbos pressure by dumping the usually excess pressure into the exhaust and stops over boosting or so i think.
    could also be your N75 might not be working properly.
    can't really think of owt else
    ou ou ou a hose popped off somewhere??
    S3 - Gone but not forgotten!
    Oct 2007
    42
    if it was the actuator do you know how i would fix it.ive never had it off before ? thanks
