JMB RetrofitsVolks Autos
    S3 amd map,coilovers,upgraded heldex,lcr spliter..
    Apr 2007
    Bristol
    228
    can't open my door!
    the passenger door will not open from the inside every time,
    the door pin pops up but it wont open.
    any ideas?
    treblesykes's Avatar
    Nov 2004
    york
    688
    are you parked too close to a wall?
    joost's Avatar
    Nov 2005
    Lancs
    1,166
    What's wrong with climbing out of the driver's side? Or getting out Dukes of Hazzard stylee...
    On a more constructive note, does the door open from the outside? If so, may be worth checking if the cable has become disconnected from the interior handle somehow?
    Justin
    2001 VW Golf 2.3 V5 (170) Highline, Indigo Blue - standard, for now...
    A4 (B5) SE with a few slight amendments here and there (sold)
    Apr 2007
    Bristol
    228
    it will open from the outside evry time but not every time from the inside, the door pin pops up and down on the lock unlock button.
    the conecting rod cant of come off as it would not work at all then.
    im going to have to get the door card off and have a look i think.
    Oct 2007
    Norwich
    55
    I had exact same problem on my A3, I took the door panel off and an re- hooked the outer cable. Will take 5 mins
    Jun 2006
    712
    the hook can get trapped going up and down unless it is put in properly, whip off your door casing and just check it's ok. this should sort it, as i had a similar problem.....
