Results 1 to 12 of 12
    Jul 2007
    14
    Door wont shut properly...
    When I shut the drivers side door, it doent appear to latch on properly, I have to either very gently shut to the door or push it in.
    Has anyone experienced this before and if so, is there an cheap fix without having to goto the main dealer?
    Thanks in advance.
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    I have heard that you can not adjust the door, but a simple technique of jacketing up the door slightly can re-align the door and solving the shutting issue.
    Something I might try at the weekend, a few people should be along soon to confirm this !
    I hope!
    J
    Oct 2006
    9
    If you hold the door handle up and close the door slowly, does it look like the top of the door lines up with the trim on the bodywork?
    rodenal's Avatar
    Oct 2006
    1,982
    Yeah you can try carefully just bending the door upwards, if this isn't working or you break the pins then these will need replaced.
    the catch on the bodywork can also be moved, not sure this would realyl help you tho
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    Jul 2007
    Huddersfield
    218
    had the same problem a few months ago. the door does drop over time in which you can just jack it back into place.
    be careful though not to over do it so just go slowly.
    Jul 2007
    14
    Hi
    Thanks for the info.
    How does one go about jacking the door back up?
    I had a look at the alignment and it does look slightly out.
    I took the car to audi prior to posting on here and therefore didnt know anything about the doors dropping, they said I need a new door lock mechanism
    Jul 2007
    60
    Can you use the jack at the back of the boot? Is that good enough to do the job?
    simonwjones's Avatar
    Aug 2005
    staffs uk
    344
    My last 3 A6's have done this.
    If you shut the door and find it doesnt quite engae the lock properly, try shutting it and keep the pressure on the door as its shuts. If this works, try spraying wd40 into the door lock and closing and shutting the door a few times.
    Simon
    A6 2.5tdi Quattro Sport 180
    A6 1.9tdi Avant ................. Gladly missed
    A6 2.8 Quattro .................. Sadly missed
    Quattro 2.8 Coupe ............. Sadly missed
    RNS-E, Audi BT, Phatnoise
    Apr 2009
    76
    same problem here too. if i shut the door normally or fairly hard it sort of rebounds back half shut on the latch. then you can push it shut. It works fine if you shut it gently.
    strangely i drounded the lock in WD40 and it worked fine... for a day then started playing up again
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    You'll probably need a whole new door lock mate. I have an issue with my drivers lock where it doesn't unlatch every time when opening from the out side. My passenger lock has a knackered microsensor which is stopping the alarm from arming.
    I've done some research into doing fixes but it all looks a massive pita so i'm getting 2 new locks fitted by a VAG specialist for 100 a lock!
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    cruising in 6th...
    Jan 2009
    26
    Before you try jacking it up, give this a go. There are two 10 or 12 mm bolts towards the bottom of the door. tighten them up and see if it shuts. I had that problem where it just pops back open, tightened them and now its fine.
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Quote Originally Posted by SpKM3 View Post
    I'm surprised they didn't say you need a new door... what a bunch of jokers
