Chris NottJMB Retrofits
Page 2 of 2 FirstFirst 12
Results 41 to 76 of 76
  1. #41
    JamS3's Avatar
    Jun 2003
    Stockton-on-Tees
    2,248
    Prawn
    There is no point fitting a J valve after a remap when you haven't had it done yet. You may aswell get a custom remap and speak with the tuner to incorporate the gain your J valve would have given.
    NOW - Audi S3 Facelift - Sprint Blue, RNS-E Sat Nav, SDS, Bluetooth Phone Prep, Bose, Cruise, Buckets, FBMFSW, Adaptive Lights, Int Light Pack, Tyre Pressure Monitor, Piano Black Inserts, Through Load, Auto Dim RV Mirror/Wing, Auto Wipers/Lights, Folding Door Mirrors, Heated Seats, Ipod Dock, Front Arm Rest, Rear/Front Parking Sensors, 1st Aid Kit, Rear Arm Rest, H + R Springs, Front 15mm Spacers, Rear 10mm Spacers.
  3. #42
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,368
    interesting. i was under the impression that if a car is mapped with the J valve in place, it will give exactly the same boost as if it were mapped with the standard valve. thus the remap would totally negate the increased boost of the J-valve.
    im sure there were a few threads on this when i joined back in november. many people saying fitting the J valve before a remap was pointless, as the remap would work around the increased boost of the N75 to deliver the boost the map was inteneded to run.
    sorry if that sounds a little confused, it makes sense to me, sort of!
  4. #43
    Stewart's Avatar
    Feb 2005
    Blackpool, UK
    696
    Quote Originally Posted by Prawn
    Yes you're right which is what Jam was saying
    Mike at Jabba told me this personally, he preferred the C valve as fitted to early ECU's (non drive by wire) as it helped with a flatter torque curve...
    Fitting the J valve post map DID make a difference but I was overboosting and hitting limp.
    Rarrrr! I'm not Lesdyxic!
    There are three kinds of people in the world, those who can count, and those who can't.
    Clicky Here!
  5. #44
    dubbers's Avatar
    Motown UK
    Feb 2007
    Worcs
    17
    I ran the 'J' in a remapped BAM engined TTR for most of the summer last year. My experience was that it was fine (and made the portly TT quite savage), until about November or so when it kept going into limp... Vagcom reports
    17963 - Charge Pressure: Maximum Limit Exceeded
    P1555 - 35-00 - -
    and occasionally accompanied with
    16487 - Mass Air Flow Sensor (G70): Signal too High
    P0103 - 35-10 - - - Intermittent
    In my situation the car effectively became boostless. To resolve was a few seconds with VagCom to reset. Since then I've swapped back to the standard N75.
    2.0TDI 170 DSG - SLine - IBIS White - 18" 5 Arm - Rear Tints - Ipod
    05 TTR - Black - 18" BBS X-Spoke - AmD Stage II
    Gone but not forgotten - 8L S3 AmD Stage II
  6. #45
    Daniel Vzla's Avatar
    Dec 2006
    Caracas / Venezuela
    84
    Ok so summarizing, all the engines but the AGU go into Limp with this mod? a N75 J in a chipped AGU will make any difference?
  7. #46
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by dubbers
    Exactly my experiences...although it was safe for the engine for me to run an alternative N75, it made the power delivery very savage...and kept hitting limp mode.
    I too had to reach for VAG Com to get any boost back...
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
  8. #47
    AndybS3's Avatar
    Jun 2003
    Central Scotland
    233
    I found the J valve a lot more aggressive on boost and initially would hit limp mode but as you get used to it there was a way of driving round it.
    It also helps if you have APR software with fault code reset as it's just a matter of dipping the clutch and running through the reset feature after hitting limp
  9. #48
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by AndybS3
    On mine, with the J valve fitted, it would hit limp if you drove at small throttle openings and let the boost build slowly...if you dropped a gear and mashed the throttle open wide, you were safe.
    Fine on back roads...not so good on Motorways.
    Please note:
  10. #49
    scib4's Avatar
    Beep-Beep!
    Dec 2006
    East Kilbride
    269
    AndyB, where you up at Knockhill on Saturday in the 340R?
    There can't be many of them in Scotland!
    Mike
  11. #50
    AndybS3's Avatar
    Jun 2003
    Central Scotland
    233
    Exactly the same here Glen.
    Wasn't me at Knockhill mate, still too chilly yet for my liking, seemingly there's about 6 340's in Scotland 3 or 4 of them in Aberdeen
  12. #51
    dultanur's Avatar
    all promises, no action :)
    Sep 2006
    Istanbul,Turkey
    407
    can't help it...i love your car mate!!! next time you take a drive give it one for me...
    2000 Black S3 (Sold, then totalled) - 2008 A3 1.4T Sport
  13. #52
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Really?
    Never seen any about...
    I know a lad with an Atom...but don't know of any 340 owners.
    In saying that...there are a lot of rare and expensive cars 'hidden' in Aberdeen...more so than most people think.
    Please note:
  14. #53
    AndybS3's Avatar
    Jun 2003
    Central Scotland
    233
    I was talking to another Scot on one of the Lotus forums from Aberdeen Glen who had one and he mentioned there were 3 or 4 up there.
    They really are for the track alone and good weather, most if not all will be tucked up in a garage until Summer
  15. #54
    Fandango80's Avatar
    Oct 2004
    Poole, Dorset, UK
    71
    Limp Mode...
    Guys this looks like something id like to try but im concerned about limp mode... if my a3 hits limp mode, will it last just a few mins or will it stay in this mode until it is physically reset with vag com?
    Cheers for all the interesting posts on this one lads!
  16. #55
    Bellic's Avatar
    Dec 2006
    253
    if you switch the ignition back off and on usually resets the limp mode
  17. #56
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Thinking about doing this but can someone give a clear answer, how do you get rid of limp mode if your car goes into it?
  18. #57
    scib4's Avatar
    Beep-Beep!
    Dec 2006
    East Kilbride
    269
    Blast from the past..........
    Mike
  19. #58
    Shy19s's Avatar
    Oil running through my veins.
    Apr 2008
    London
    902
    I miss reading techinical stuff like this... Hopefully matt will give a detailed report on what his car is running so we can all have a very interesting read!
    Totally addicted to boost.
  20. #59
    larsmate's Avatar
    Apr 2004
    114
    Clear the fault code with VAG-COM.
    Black S3 | MY09 | APR 3.4 Stage 2+ | RNS-E LED | Tints | 19" OEM RS3 Rotors | APR DP | APR HPFP | WALK | Bilstein B14 Coilovers | Lamin-X | Ashtray delete | P3 Gauges integrated boost gauge | BlueVAG VAG-Check |
  21. #60
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    What do you do if you havent got vag com? Are you sh*ted!
  22. #61
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,519
    Nono, if your car goes into 'limp home' mode, all you need to do is switch the car off and then back on, and it will be back to normal.
    It's will probably log a DTC which will com up in a Vagcom scan, nothing to worry about unless you have actually broken something.
    You've got to have a laugh! For Sale:LCR Brakes - ÂŁ400
  23. #62
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Thanks jojo, thats all i needed to know, didnt want the car togo into limp mode an leave me up sh*t creak
  24. #63
    vetch's Avatar
    S3
    Apr 2009
    412
    Quote Originally Posted by jojo View Post
    That question has been asked many, many times, and to my knowledge, no one has actually answered it properly. Nice one Jojo
    Audi S3
  25. #64
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    The thing is, if you do the N75 valve mod and it puts your car into limp mode and you reset it by turning off and on again, limp mode will come straight back again unless you revert the valve mod back to standard again.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  26. #65
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,519
    Quote Originally Posted by Westle View Post
    It will go back into 'Limp home' mode after a reset if you decide to drive it like a loon again straight after you restart it. It usually only goes into limp mode when the ECU detects a boost spike or something similar, which is what the changing of the N75 does to trick the car into a wallop of torque, though I stand to be corrected.
  27. #66
    Feb 2008
    2,817
    so does this happend with everyone with the n75 valve?
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
  28. #67
    vetch's Avatar
    S3
    Apr 2009
    412
    Not so much on the APY S3s apparently. Ive read this on more than one occasion, but it could be hearsay.
    Audi S3
  29. #68
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Your right vetch, its been asked acouple of times in this post and no one answered it, cheers jojo
  30. #69
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    Quote Originally Posted by vetch View Post
    my apy is fine been runing mine for some time i had to bypass my n249 valve though for it to run smother but think it was because the valve was knackered more then because i had the 75j fitted
  31. #70
    fran-s3's Avatar
    1,090
    Happened with my 01 AMK engine when I fitted the J.
  32. #71
    Feb 2008
    2,817
    thats what i was wondering fran? i've got an amk too so wanted to know what peoples experiences were
  33. #72
    Aug 2010
    bradford
    1,252
    hi just wondering what would be the best n75 for my amk 210 s3 as i dont have a clue with everything iv been told is dif wih them on dif engine modules just think its on its way out thats all tar
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
  34. #73
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quote Originally Posted by s3gazz View Post
    Std F valve
    <tuffty/>
  35. #74
    Aug 2010
    bradford
    1,252
    ok cheers ill keep that then tuffty
  36. #75
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    I have gone from standard F valve to J Valve over the last few days with an APY engine code. (Let it be known that I was told not to but when your as green as grass you like to try all the options what everybody else has already tried but dont listen to what people say lol, a bit like my 18 year old son lol) I fitted it the wrong way round to start with and hit limp mode 2wice in half an hour and then fitted it right way round and everything was hunky dory could notice a real change but then the sh@t hit the fan and hopefully i dont have big problems I will start a thread 2morrow to find out
  37. #76
    Aug 2010
    bradford
    1,252
    Quote Originally Posted by cecilthesausage View Post
    tar mate hope all goes well for ya i hit limp mode at 20psi with the standered f valve on my amk so god nose what it would be like with the j valve
