Monster MotorsportEM Tuning
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By mattyboy199
Thread: How to Remove Aerial Base?
    dot32's Avatar
    Aug 2003
    ewell, surrey
    47
    Question How to Remove Aerial Base?
    Does any of you guys out there know how to remove the aerial base on a 2001 a3, I was told to remove the rear interior light and then there should be a nut to release the base, but where the nut should be, there is a small rectangular box of electronics? this box won't prise off and the base seems not to twist either. Any way will be greatly appreciated!
    cheers
    j.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    I'm pretty sure the nut for the aerial base is on the outside of the roof. You unscrew the aerial and then lift up the base cap. You should then see the retaining nut.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,289
    The nut is under the rear interior light. If you remove the light from the interior roof lining you'll see the nut which holds it on.
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Cheers for clearing that up :-)
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    There are two types of aerial bases, the 1st has the nut inside & the amplifer is built into the cone shape which sits on the roof. the 2nd has the nut outside & the amplifer shaped as a metal box sits inside. Check out what you have.
    Matt
    Dani_B19 likes this.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    dot32's Avatar
    Aug 2003
    ewell, surrey
    47
    Quote Originally Posted by mattyboy199
    Matt
    I've got the 2nd type of base, does this mean i have to prise off the base somehow?
    cheers
    j.
    Nov 2005
    UK
    1,688
    When i bought the replacement which is the 2nd type, i found that a rubber cap is used as the cone which just sits over the bolt that holds the unit in place. Remove your bee sting aerial (that screws into the base) you should find the rubber cap easily comes lose to reveal the bolt. Pretty straight forward yours could be glued on if its factory but use some brut force !
    wanted for 8L S3:
    Milltek system
    dot32's Avatar
    Aug 2003
    ewell, surrey
    47
    Thumbs up
    Mate, nice one for the info! just tried it and off came the base! replacing it with the audi shark fin, so hopefully I'll stick up a pic to show the result.
    Again, many thanks guys for all your help!
    Nov 2005
    UK
    1,688
    will the shark fin even pick up decent radio reception ? no offence i would stick with standard but thats me.
    wanted for 8L S3:
    Milltek system
