Volks AutosChris Nott
Results 1 to 8 of 8
    scarydave's Avatar
    Sep 2007
    northants
    URGENT HELP!!!!caliper wind back tool
    im changing my rear discs and pads this weekend so i thought id read a few posts to get some tips.seeing that i need a wind back tool i went to buy one today but theres 2 types and the shop could not specify which 1 was for an a3.they were both 2 pin but 1 was flat and the other had a lip around the edge of the tool.can anyone shed some light as i need to order it 2moz so its here for the weekend!
    Cheers peeps!
    clcollins's Avatar
    Mar 2004
    Lancashire
    276
    I presume that one of the tools you have seen is the one from Laser Hand Tools? Although it doesnt say on the packaging it does fit VAG cars, I bought mine from GSF, double checked with them and have used it since, so I can say yes it works.
    Audi A3 1.9TDI Sport Quattro
    scarydave's Avatar
    Sep 2007
    northants
    there both from laser hand tools, so was it the one with or without the lip round the outside??????
    Jun 2006
    298
    Got mine from Halfords, two dimples on either face, one where they're close to the outer edge, the other closer to inner edge. Fits no problem, though I had worn my pads so much that I had to "modify" the side which didn't fit my car.
    Worked a treat after that!!
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Think this is the one you need
    http://www.lasertools.co.uk/item.aspx?item=356&cat=518
    At least that is the one I have and used on my Mk4 Golf.
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    rodenal's Avatar
    Oct 2006
    1,982
    both should work ok on the car, as long as its not a big lip its not going to affect much, iirc mine has a small lip, cant see how a flat one wouldnt do the same job tho, assuming the pins are in the same location
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    batwad's Avatar
    Jul 2006
    Beds
    841
    Quote Originally Posted by marms
    Yep, that's the one I used to do my rear brakes.
    03 A3 (8L) TDi quattro Sport, Aluminium Silver with leather, armrest, cruise, xenons and me at the wheel
    scarydave's Avatar
    Sep 2007
    northants
    thanks for all your help guys i think i have the right one, i guess ill find out 2moz!!
