Volks AutosAH Fabrications
    Feb 2007
    24
    Engine light flashing
    Hi All,
    Today coming home from work my engine light flashed on twice,I got home and plugged vagcom into the car,The only code it flung up was "brake switch" has anyone any ideas as to what this is ??
    Regards Jack
    petewon's Avatar
    Dec 2004
    Newcastle
    514
    Possibly an intermittent fault with the brake switch under the pedal. I had one go on my first A3, I think its quite common. Cheap enough for a new switch though, I think there about 15 ish.
    You might wanna get someone to check your brakes while you pumping the pedal.
    Pete
    _______________________
    8P A3 2.0 FSI Sport, Leather/Alcantara, Bose, Xenons.
    craig_007's Avatar
    Sep 2006
    48
    If it were the brake switch would this still show on the engine warning lamp ??!!
