Badger5Monster Motorsport
Results 1 to 12 of 12
    Jul 2007
    60
    Adjustable rear tie bar installation
    Hi all, I just received my adjustable tie bar from ECS and would like to put it on my S3 ASAP. But I wonder should it replace the upper tie bar or the lower one since I found two on each side under the chassis.
    Any input would be welcome. I am sure someone on the forum have them installed. Thanks.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,587
    The lower ones are the preferred choice methinks, but there's a few members that have changed the top ones, doesn't make much of a difference I think.
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Quote Originally Posted by jojo
    Jim at Star Peformance explained some reason why its best to have them on top. Can't remember it now, Sorry. He was in a good mood and have a bit of a tuning rant. Could be something to do with the driveshafts and pushing the hubs out. Or something to do with it adding a weaker link in the system and should be less affected on top.
    [/sarcasm]
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Jim and I went thtough all this too, as mine were the first set he'd fitted...
    In my view, the top is where they should go.
    It means you are keeping the rear CVs un-loaded, rather than pulling the hubs further in and potentially loading the CVs, and I'm more keen of having the solid arms on the bottom as I assumed they'd take more of the loadings
    The bottom is the easier place to fit them though...so many fit them there.
    I don't think there is a definitive answer...
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Cheers Glen. I wasn't as far off as I thought I'd be.
    [/sarcasm]
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Correct on both counts Chris...
    Please note:
    Jul 2007
    60
    Alrite, thanks mate, I will get it replaced the upper bar.
    But would it be more difficult to adjust to use it as the upper bar?
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by jomnhta
    Yeah, slightly more difficult to adjust...but you should only need to do it once, or very infrequently.
    It'll be harder to fit too...you have to take more 'stuff' off, or move more out of the way.
    Please note:
    Jun 2006
    712
    dont mean to hijack this thread, but I want to change the springs and dampers on my S3, how low can i go without the need to fit adjustable tie arms?
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Nothing...
    Even the quattro GMbH cars are known to have adverse wear issues and they are 10mm lower than standard.
    Basically, if you lower it at all, you should fit adjustable tie bars...not only will you get improved tyre wear, but a far better drive, more predictable handling, better traction etc. Well worth doing.
    Please note:
    Jun 2006
    712
    cheers Ess_Three
    s3ollie's Avatar
    Jan 2007
    752
    i fitted my bars on the top only because it would widen the rear track by pushing the tops out rather that pulling the bottoms thus reducing rear track
    8P S3
