EM TuningAH Fabrications
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    947
    Rear seat belt problem
    My car just failed the mot for a centre seat belt that won't pull out of its reel,any body else had this problem,if so how did you fix it.I have a spare interior in the garage,but they have the same problem.It looks a nightmare,as the reels are built into the seat back and all the trim has to be removed to swap the reels over.HHHelpp
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO ST2 MAP ,MILLTEK CATBACK EXHAUST,PANEL FILTER,034 INTAKE PIPE.
    Feb 2004
    2,036
    common on golfs too. you find if you out the seat down you eventualy wont get it up again as the belt tightens when its down and digs in the seat once put back up.
    if you can, take the tension off the belt, by unclipping it from the underneath the seat, you can feel the rind that clips on the floorpan hook, with some force you can unhinge it and then the belt is loose . you will then find it will retract and extend at will.
    what you now need to do is pull some slack out so the belt once reconnected is a little loose over the seat pad, then mark the belt position whenre it goes through the guide on the seat back/side, ie where your shoulder is. Then get some rivets or even jeans buttons (from sewing shop) and put a rivet button through infornt of the shoulder guide to stop the belt retracting too far and going under tension.
    Thsi certainly hlped my golf and its good now 3 years on, but I am afraid the mechanisms are a bit crap in the back and eventually it will go bad and need replacing.
    ANDYTQ's Avatar
    Oct 2003
    947
    Thanks for the reply,i have tried all that but it still wont budge.
    ANDYTQ's Avatar
    Oct 2003
    947
    After 2 hrs of swearing at it yesterday,today it decided to fix itself,thank god.
