Chris NottSky Insurance
Results 1 to 12 of 12
    Garrity's Avatar
    Jan 2007
    Wheel alignment - Ł150 at audi dealer :O or Ł25 from local tyre place?
    Hi all,
    Car's due for a service and I need to get the wheels aligned so I enquired over the phone how much this would cost - Ł150 was the reply - then he talked about because it's 4-wheel drive and they are doing it cheap blar blar blar.
    Now my local mot/type place will do wheel alignment for Ł25 (http://www.basingstoketyreandmotcentre.co.uk/) - my question is: Is this just high dealer prices or will audi look at/change something that the cheap tyre place won't?
    Chris
    S3 Nogaro Blue - 2001 Facelift, 210bhp
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Audi will use a beissbarth unit to do your wheels which iirc is used by all vag service centers, the Ł150 part is because audi probably charge around Ł80 + vat an hour to work on your car, Jabba sport do 4 wheel alignment for Ł60 using the same equipment
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    The other reason that its £25 is because they are an MOT centre, so there going to be doing a service like that more than audi would so they can afford to provide it to you a lot less than audi
    Garrity's Avatar
    Jan 2007
    I know the basingstoke place has some laser or infra-red alignment thing - not sure if that is similar to this beissbarth unit?
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    Maybe I don't understand this but the rears are fixed anyway aren' they so how can you do alignment on the rears? Surely you just match up the fronts to the rears so just a tyre place would do. Is it the fronts that are out of line?
    Jay
    Aug 2006
    323
    I had mine done a few months ago. 1 of the tracking arms had seized which had to be replaced before it could tracked, this cost Ł15 then cost me Ł20 to have it aligned! They used some infra red device. The mechanic even showed me how much the wheels were out before he started to align them. Its been perfect since.
    I had been to a few garages beforehand....all said that Audi's needed to be alligned by the stealers.
    Kwik fit also use the same device but were charging around Ł50.
    and it is only the front wheels which need doing.
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    If you're getting quotes for £25-50 for the alignment, then I'd very much doubt its a full four wheel alignment. You need the front wheels lining up with the rears to make sure everything is as it should be.
    [/sarcasm]
    Jun 2003
    World of my own
    9,813
    Find a 4 wheel drive specialist centre (supertracker), don't use Audi or a high street place.
    Should be about £75. And no it's not just the front wheels.
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    I thought 4wheel alignment is where you align the front wheels to the rears. Am I missing the point here or are the rears fixed therefore no movement? Isn't it the tie bars which makes the movement? therefore no need for Beissbarth?
    Garrity's Avatar
    Jan 2007
    Quote Originally Posted by Jay
    Ah, I thought cause of the four wheel drive on the S3 the rear wheels wern't fixed (as they are on my 205) - though this is just an assumption as I has the front wheels aligned when I had new tyres fitted a while ago and even then the car still went right when I centred the steering wheel - looking at the printout I got back then it said the rears where off centre so I assumed they could be adjusted.
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Rears have a slight toe adjustment. Camber is only adjustable if you fit the tie-arms.
    [/sarcasm]
    Jay
    Aug 2006
    323
    Quote Originally Posted by Aky
    I thought the same thing. I asked the mechanic this question and he told me that on an A3 the front wheels are supposed to be square with the rears.
    I suppose you get what you pay for.
