Sky InsuranceAH Fabrications
Results 1 to 11 of 11
Thread: DV fitting
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    DV fitting
    got my DV through the post from AmD (next day, clips and post - Ł65+vat [img]/ubbthreads/images/graemlins/grin.gif[/img] )
    Never fitted one before, pleased to say looks easy enough....that said I have a question.
    It has come with a choice of 2 ?pipes? to screw into the top, different ID and OD.
    I have a '02 225 ( pre oneclick [img]/ubbthreads/images/graemlins/smile.gif[/img] ) does anybody know which i should use, and why there is a choice?
    cheers.
    89
    Re: DV fitting
    SMALL ONE BUT CHECK ON YOUR DV AFTER YOU REMOVE ONLY TAKES ABOUT 15 MINS TO CHANGE.
    PaulRS3's Avatar
    UK
    1,006
    Re: DV fitting
    small one.
    leave the audi clip on the top pipe and it will slide over and onto the plastic hose tail a treat.
    Engine cover off, is easiest way to get to them.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,578
    Re: DV fitting
    The pain in the rear end about changing the original DV, is the original hose clamps from factory. [img]/ubbthreads/images/graemlins/burningmad.gif[/img]
    Apart from that, very easy!
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    Re: DV fitting
    cheers guys.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,578
    Re: DV fitting
    glad to help!
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,578
    Re: DV fitting
    I have put one an all of them but the top hose (smallest one) as it was a really tight fit with the AMD Viper DV......there was one with the original DV but.
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    Re: DV fitting
    agreed with mike, clips on all 3 hoses.
    i took pauls advice on the top hose and just pulled it off the Bosch unit .... snugly fits over the AmD pipe with no problems so far.
    Woodster's Avatar
    Welcome to my world...
    Dec 2003
    Mighty Mighty Yorkshire
    83
    Re: DV fitting
    Will fitting a Viper DV invalidate your warranty?
    Jul 2003
    Oxfordshire
    79
    Re: DV fitting
    [ QUOTE ]
    [/ QUOTE ]
    Technically yes. However most Audi stealers don't care unless it is the main cause of a fault they are repairing under warranty.
    Woodster's Avatar
    Dec 2003
    83
    Re: DV fitting
    Fair enough, I'll save the effort of changing it back unless I have to. Thanks.
