Volks AutosEM Tuning
Results 1 to 7 of 7
    Dec 2006
    84
    Coin Tray Removal
    2003 S3
    You kow the coin tray / cubby hole thin above the ashtray? My lid does not stay down anymore, was wandering how it is removed to investigate repair or renewal?
    Aug 2007
    Aberdeen
    119
    I have the same problem so advice needed too!
    Dec 2006
    84
    Hi Dazz
    Keep atching here and hopefully someon can shed some light on it - or I might just have a closer look myself.
    A3steve's Avatar
    Sep 2006
    126
    Hi,
    look under the lid where it swivels you will see four rectangluar holes (two on either side) on the inner one of either side place a small straight bladed screwdriver in at 45 degrees (toward each corner) and press down the tabs on both and pull.
    Alternatively if you want to risk it - with a good tug it will come out.
    Hope this helps
    Dec 2006
    84
    Thumbs up
    Thanks for that, i'll have a go tonight .
    A3steve's Avatar
    Sep 2006
    126
    Came across this, these are the tabs you are looking to free.
    Steve
    Dec 2006
    84
    Thanks Steve - as they say, a picture can tell a thousand words!
