Will these wheels fit an S3
they should fit but you may need spacers because of the high offset
You wont need spacers with standard brakes.
I have a set of 44mm offset wheels and they fit just fine.
Yea 38 is the right offset. And assuming its a golf 4 motion they will fit fine.
make sure the centre bore diamater is the right size too, think it's 57.1mm, but most aftermarket alloy wheels you can change these
If the wheels have come off a Golf V6 4Motion, they will bolt straight on with no mods what so ever... Same suspension and hub setup between S3 and Golf IIRC
Defratos said:
sweet, what type of spacers and what sizes would I need, for the front or rear?
:confused: :confused:
defratos mate, has some hacked into your account?
