JMB RetrofitsSky Insurance
Results 1 to 10 of 10
    Defratos's Avatar
    You’re Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    Question Do any of these Bushes look worn?
    Hey there guys, been getting some really annoying creaking noises from what seems to be my arbs (as the noise only comes into play when I'm driving in and out of my drive) or over an uneven surface. So I decided to take the wheels out and have a look around to see if I could spot anything obvious, and I can't. All the bushes seem to be fine to be, and so do the ARB links. I'm hoping it's not something like a bent ARB (how would I be able to find that out without taking the ARB apart)? Have a look at the pics and if anyone can spot anything funny then let me know.
    Rear Right ARB Inner bush
    Rear Left ARB Inner bush
    Front Right ARB Inner Bush
    Rear ARB Link (both sides look the same no difference)
    Front ARB Link
    I also checked the Tie-bar bushes and steering rack and both seem to be healthy.
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
    daz2347's Avatar
    Jan 2007
    Berkshire
    81
    Mate im no expert but i think to check them you need to remove them to have a good look all round..
    Sex on tv is good Just dont fall off
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    its impossible to tell from pictures, only a totally nick nacked bush would show up on a pic tbh. theuy may need lubing to stop the creaking or try loosening the arb bushes and lowering the wheels onto some chocks of wood then tighten them back up with the weight on the wheels.
    frommemory those bushes havn`t been on your car v long so unless they incorrectly fitted they should be ok.
    red to red black to black blue to bits
    Defratos's Avatar
    May 2004
    2,230
    Ok, thanks for that. If I was to lube them up whats the best product to use? because I think I need to take that out of the equation first.
    Audi S3-BAM
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    id like to know this too, wots best to lube them with?
    2001 Audi S3 - Facelift - Revo remap - Forge 007p DV - BMC Panel Filter- Type R Ariel - Aero wipers - n75j valve.
    Defratos's Avatar
    May 2004
    2,230
    and would you advice cleaning them before applying any grease?
    Audi S3-BAM
    cjhill's Avatar
    hmmmmm interesting.
    Aug 2005
    UK, South
    335
    the best lube i find is a silicon based one - infact i think it is called silicon lubricant.
    got mine from halfrauds.
    I think things like wd40 can rot the rubber over time
    Call of Duty Zombie Slasher.
    thats me
    Sep 2004
    west yorkshire
    3,762
    yes I agree the grease has to be silicon based as far as I know. also yes to the cleaning
    Defratos's Avatar
    May 2004
    2,230
    sweet, thanks. Just out of curiosity, would be ok to just clean up and lube the bushes without taking them out? (I'm hoping they'll eventually seep in or something)
    Audi S3-BAM
    Jun 2007
    446
    my golf used to make similar noise. put set of powerflex bushes in wishbones and solved the problem, also tightens up the handleing loads! worthwile doing it anyway imo
    hope that helps
