JMB RetrofitsAH Fabrications
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By badashbrighton
Thread: Cleaning MAF and Throttle Body
    dot32's Avatar
    Aug 2003
    ewell, surrey
    47
    Hi all, looking to clean both the maf and the throttle body this weekend due to lumpy idling, (never bothered with my old a4 - when the idle went lumpy, I'd just switch on the ac compressor which would stop the car from stalling - not the best thing to do as when the throttle body needed replacing this cost me 450!!) Anyway can anyone point me in the right directions for a photo guide of the two procedures, saw them awhile ago, but can find them anywhere now!
    Cheers all.
    CLS3's Avatar
    Every penny goes on the Audi!!
    Dec 2006
    Bath/Oxford
    97
    MAF Cleaning... http://www.wak-tt.com/mafclean/mafclean.htm
    TB Cleaning...for A3 1.8T and similar not S3 due to the throttle body being on the left of the inlet manifold and not on the right as in 210/225 S3/TT but same process applies to all http://uk-mkivs.net/forums/thread/222737.aspx
    Hope that helps.
    Audi S3 Nogaro Blue - Brembo GT Brake Kit, Milltek Cat-back Exhaust, Neuspeed ARB's Front 22mm Rear 19mm, Forge Motorsport TIP, Hyperboost Rercirc DV, Aero Wipers, Leon Cupra R Front Splitter, Aluminium Mirrors, Black RS4 wheels with Toyo T1R's, H&R and Forge Motorsport Wheel Spacers!!
    dot32's Avatar
    Aug 2003
    ewell, surrey
    47
    Thumbs up
    Mate, your a star!!! have been looking for ages!!!
    p.s Do I need to disconnect the battery for any of these procedures, as I don't have the code for my concert deck?
    CLS3's Avatar
    Dec 2006
    Bath/Oxford
    97
    Also see this... Throttle Body Clean. a lot of good stuff on there but to sumurise, it might be worth getting a new throttle body gasket part number 028129748 and 1.82 inc VAT from Audi (bought mine today!) and the throttle body bolts are done to 8Nm of torque.
    I think people say to disconnect the battery to reset the throttle body if it is drive by wire, is yours cable or drive by wire? and i'm sure someone said that they suprisingly didn't have to put in their headunit code.
    If yours is cable operated might be worth not disconnecting the battery so that you def don't need the headunit code.
    dot32's Avatar
    Aug 2003
    ewell, surrey
    47
    Thumbs up
    Cheers fella for the info, Mines a 1.8t with DBW so probably will have to disconnect the bat... oh well my girlfriends singing ain't that bad if the radio goes safe...
    cheers!
    Jay
    Aug 2006
    323
    Quote Originally Posted by CLS3
    Might sound like a daft question but how would you measure 8Nm?
    Would tightening the bolts as much as possible not be safe?
    thanks
    CLS3's Avatar
    Dec 2006
    Bath/Oxford
    97
    8Nm can be measured accurately using a torque wrench, tightening the bolts as much as pos is ok, just as long as the surfaces of the inlet manifold and the trottle body seal against the gasket...and don't over tighten them and strip the threads!
    8Nm is not much torque so if they are done up tight with a small (1/4" rachet or allen key) that should be fine.
    Mar 2013
    Brighton, UK
    Thumbs up Definitely worth doing!
    Quote Originally Posted by dot32 View Post
    Hi all, looking to clean both the maf and the throttle body this weekend due to lumpy idling, (never bothered with my old a4 - when the idle went lumpy, I'd just switch on the ac compressor which would stop the car from stalling - not the best thing to do as when the throttle body needed replacing this cost me �450!!) Anyway can anyone point me in the right directions for a photo guide of the two procedures, saw them awhile ago, but can find them anywhere now!
    Cheers all.
    I just cleaned my throttle body and replaced the spark plugs and wow what a difference. My A3 was getting a bit sluggish pulling off in 1st and 2nd and MPG was really suffering too. When I took it apart I found loads of black gunk built up, I didn't remove the entire throttle body tubing but did remove the unit from the engine and left the fuel supply attached and managed to clean it just fine - I also advise not touching the butterfly flap with your hand and using the throttle pully on the side to open it while cleaning, if you use a decent carb cleaner with a straw nozzle it blows most of it away. Just saves you some extra time, I would say it took me about an hour to replace the plugs and clean the TB.
    If you are experiencing a sluggish performance and idling is rough and bounding up and down you will see a massive improvement. I didn't need to use a VAG-COM and it sorted itself out nicely. I have purchased the cable on ebay for just £5 as I am a little geek and want to play with the settings. Let me know if you have any questions.
    fazfam786 likes this.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    889
    Add Vex182 on Facebook
    You know this thread is nearly 6 years old? Good to keep it up to date for others I suppose.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    Quote Originally Posted by Vex182 View Post
    The youngest 8L is 9 years old so I guess nobody is worrying about time.
