Results 1 to 13 of 13
    Feb 2007
    Harrow
    221
    Maintanance apart from servicing
    Hello People
    I have just cleaned the throttle body which was quite easy from looking at other posts showing how its done. I would say it definately worth doing.
    Just wondering if theres anything else like that which is quite easy to do that is worth while doing. My car has done 98k.
    rodenal's Avatar
    Oct 2006
    1,982
    Unless the car drives oddly or there are any noises/bumps/rattles just do your regular servicing and dont worry about it lol.
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    Jun 2006
    712
    in my opinion you should change the fuel filter, gearbox oil and diff oil
    These are not done on any service, which is just stupid......
    Fuel filter is under the body at the back on the drivers side.
    The Diff and g/box oil, use Silkolene SYN 5 fully synthetic GL4/5 gear oil, available from Opie oils, you'll need no more than 4 litres to do the lot, but get 5 just to be sure
    Jul 2005
    2,488
    at that age it should have the oil pump replaced and the strainer cleaned out. Not a simple task though.
    Jun 2006
    712
    oh yeh I forgot, I had the above done just for piece of mind. However, the pump, strainer and sump had virtually no gunk or residue in at all. Got mine done at APS in Brackley, wasn't that expensive at all.....
    Feb 2007
    Harrow
    221
    cheers Jon you must be in tip tip condition. I guess i would have to change the sump gasket aswell?
    Dec 2006
    190
    Quote Originally Posted by jonS3
    you should change the fuel filter, These are not done on any service
    Be worth checking with who ever last serviced your car if this has been done or not, as we always replace the fuel filter at every service.
    Feb 2007
    Harrow
    221
    cheers Dan i have bought the fuel filter just gotta get round to do it, just worried about breaking the clips (special)
    Audi A3 54 plate 2.0 FSI Sport
    www.simplydents.co.uk
    Mods - 11 Rear lights, custom front matt black grille, I pod connection, S3 rear spoiler.
    Jun 2006
    712
    yeh, I had new sump gasket, sump retaining bolts and sump gasket fitted at the same time (also had new thermostat and coolant, but that actually needed doing
    Feb 2007
    Harrow
    221
    Dan i got someone to change it 2 years ago, so i thought i will do it myself this year as i undertake the oil change, pollen filter, air filter, spark plugs etc myself.
    Dec 2006
    190
    Yep, its easy to do and doesnt cost much. Definately worth doing at every service.
    Clach's Avatar
    A3 - 1.8Ts
    Jul 2007
    Oxford
    974
    Looking to find a reputable mechanic to change the Oil in my Auto Trans. A3 as a non-service item, any ideas? Berkshire area...
    Lost in Norway
    Jan 2007
    Norway
    17
    Where is the gearoil filled?
