Results 1 to 18 of 18
Thread: MAF Problems
    Aug 2007
    London
    13
    MAF Problems
    Hi,
    I have had a bit of trouble with my MAF sensor lately and need a bit of advice.
    About a month ago I was getting hesitation when accelerating steadily, but I couldn't really notice it when I had my foot down. Checked on the forums and found a few people with the same thing that suggested I unplug the MAF sensor to see if things got better.
    That seemed to work, so I went to Audi to get a new MAF. Replaced it myself, but it was still ****. Unplugged it again and acceleration was fine. It did look like it had been fitted to another car before as it had a bit of grease on it, so I took is back to Audi.
    They had the car in and ended up replacing the MAF.
    When I got the car back it was all fine for 2 or 3 days, when it started playing up again.
    Surely I can't have another faulty one can I?
    I have a REVO remap and thought this might have something to do with it.
    Has anyone else had the same problems and is there a different MAF I can use to cope with the higher power?
    S3 Dave's Avatar
    Now running on Heavy Oil
    Jul 2007
    Middle England
    432
    Had problems with MAF's before. What Air filter do you have?? Re-maps and non stock filters seriously shorten MAF life!! If you have a K+N etc the oil from these can kill it!. If you got it fitted at Audi then I would take it back. All parts with 2 year warranty etc!!! Had mine changed under warranty after 22 months!
    "Never in the field of human conflict was so much owed by so many to so few"
    Churchill August 20th 1940
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Quote Originally Posted by kevy
    It seems clear to me that your MAF is at fault, as you say it was running fine for 2-3 days, then goes faulty again.
    Note likely, but it's not impossible to have a faulty MAF again bud.
    You've got to have a laugh!
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    904
    i had a faulty MAF replaced which subsequently went faulty, got a replacement FOC and that was faulty also, the third one has been fine
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    564
    One question on this issue.
    Does a knackered MAF cause a lumpy idle too?
    Just had my throttle body off & cleaned but doesn't seem to have helped.
    ...... Waiting Paitently...
    Aug 2007
    London
    13
    It seems to on mine, yes. Only slightly though.
    Aug 2007
    London
    13
    My air filter is standard so it shouldn't be that causing a prob.
    Another thing is, I reset the ECU the other day to try and get the one touch on the leccy windows working and the car seemed run fine again for a few days. But now it's poo again.
    Anyone know why this is? Something to do with the ECU learning??
    Aug 2007
    London
    13
    Finally Audi had tracked down the problem to a leak on one of the vacuum hoses.
    They quoted me £450 for the work and £150 for parts claiming they need to remove the inlet manifold to do the work.
    I told them no of course, but now I need some help.
    Firstly, I need a pointer as to where I can get the hoses cheep, and or better hoses?
    Secondly, do I need to remove the inlet manifold to replace these? Is it an easy job?
    Audi recommend I replace all my vacuum hoses and I do agree on this one as it's done over 100k.
    Thanks in advance for any advice.
    Jan 2009
    20
    Any update and conclusion for this topic, my S3 also has same problem no matter i change my MAF to new one and still problem, unless i unplug.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Quote Originally Posted by kevy View Post
    When you swap the MAF to a new one you have to reset the ECU. This is why you didn't feel the difference before.
    Lumpy idle = vacuum leak as mentioned.
    You do not need to remove the inlet manifold to replace the vacuum pipes underneath it. I'm surprised they said that. You can remove the various engine covers and then the black metal plate that attaches to the inlet where the oil dip stick sits and you'll have room to get to things.
    You might find that it's either one of the two thin vacuum pipes or part of the breather system that's split. I've had to fix both in the past.
    Also the v shaped pipe on the drivers side next to the cam cover is a common one to fail on the S3. That's a very easy one to get to.
    You don't need to replace them all by the way, just the faulty one(s).
    Jan 2009
    20
    Instead of reset ECU, i did the Throttle Body Alignment (TBA) via VAGCOM instead which i believe ECU should re-learn the new figure but seems i didn't see any change, more funny is even no DTC show when new MAF / old MAF plug. Hope the vaccum leak thing u mentioned can help. but that part i need ask my garage do so, do you have any more detail about it ?
    1.8tplym's Avatar
    Mar 2009
    Plymouth
    49
    BUMP
    I think i am having the same problem as these guys a few years ago. The engine Mgt light has come on recently. When i start the car it will quite often run rough (like its being overfuelled) for about 20 seconds but seems to clear once underway? my idle is also a bit carp. It coughs every few seconds but not bad enough to stall the car. MPG is in around 25 but i only do to work and back at about 30mph. I put a K+N panel on so i reckon the oil has destroyed the MAF. If i unplug the maf all does seem to improve.
    so the questions are -
    Im guessing best bet is to change the Maf? (cheaper than the hoses)
    I have read elswhere that it is best to buy a new MAF from the stealers rather than ebay/ gsf etc?
    What price should i pay. about 100 inc vat?
    I guess they are easy enough to fit, its only the barrel leading into the air box?
    And how do i res-set the ecu. Is it just unplug the battery for 15 minutes?
    Should i ditch the K+N and if so replace with what?
    That should do me for now!
    Any help much apreciated.
    A3 1.8T Sport - K & N Panel Filter
    1.8tplym's Avatar
    Mar 2009
    Plymouth
    49
    Oh, and no ribbing because its a five door!!!!!!!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    I removed mine and gave it a good spray with fuel injector cleaner , blew it dry with an airgun and presto!! different car
    1.8tplym's Avatar
    Mar 2009
    Plymouth
    49
    That sounds even cheaper! trip to halfords this afternoon i think! i take it you just removed the barrel and sprayed all over? did you leave it to dry and did you reset the ecu? im full of questions today!
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    This exactly the same problem as I have, replaced the MAF but still runs the same. I think I may also have a vaccum leak.
    Every now and then when I put my foot down it seems to make more noise than go. Sometimes its quick sometimes its not but it does feel better with the MAF unplugged. I replaced that and it didnt make a difference so got my old one back.
    My car also sounds like it overfuelling when I take off sometimes weather the MAF is plugged in or not.
    Stumped now.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Quote Originally Posted by 1.8tplym View Post
    yes removed it and sprayed it, i made sure the fluid did not go into the electrics... hold it so the prong is pointing to the floor and spray both sides..it should evaporate but i used an airgun too as i was in a rush, i reset the throttle body adaptions on my liquid guage
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Rough Running At Idle - MAF, Ignition Coil, Spark Plug, VAC Leak, O2 Sensor, TB, CTS
    Missfires under Boost Flashing CEL – Ignition Coils, Spark Plugs
    Running Rich – Boost Leak, MAF, O2 Sensor, Coolant Temp Sensor
    Running Lean – VAC Leak, MAF, O2 Sensor, Fuel Filter
    Low Boost – Limp Mode, MBC, BOV, DV, Boost Leak, N75,
    High Boost – MBC Setting, N75, Spark Plugs, Ignition Coils
    Cold Start Problems – MAF, Spark Plugs, Fuel Pump Relay, CTS
    Poor Gas Mileage – MAF, CTS, O2 Sensor, AIT Sensor
    Cat Efficiency Below Threshold – Down pipe, CAT, Rear O2, RACE FUEL
    No Start – Battery - ECU, Fuel Pump Relay, Ground
    Start For 1 Second - Stall – Immobilizer
    Overheating - Waterpump, Thermostat, Head Gasket
    oil in coolant - Oil Cooler, head Gasket, Water Wetter
    Dies While Driving Timing belt, Boost Leak, MISC
    Shorts To ground CEL Fuel Pump Relay, Bad Grounds
    Pick one
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
