Monster MotorsportChris Nott
    May 2007
    67
    bad start up on 2001 1.8t
    when started the revs goes up past 1k rpm and if you set off to drive it shudders as you try and pull away but if you leave it for 1 minute the revs drop back down below 1k rpm and its fine.
    what could be causing this and can it be fixed. its been doing it pritty much since i got and i am curious as to what the hell it is.
    thanks for any help
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    this is normal when starting from cold.
    Jay
    Aug 2006
    323
    I've got exactly the same problem....Annoying as f***
    I was thinking the throttle body and MAF may need a clean so am planning to do this soon.
    IndieA31.8T's Avatar
    Apr 2007
    14
    Hi,
    I have the same problem. I had it checked with VAG.COM dude's in Kent and they pulled up a engine coolant sensor thats probably causing the problem.
    They cost £26 ish from Audi dealers. MAKE SURE you get a 'Green' sensor as this is the new one.
    Dave Jones
