JMB RetrofitsBadger5
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    vibrations/shaking when driving off
    Don't know if someone can help on this, but this is becoming more and more often now, when the car starts to move/drive off, there is a lot of vibrations on the front esp if I release the clutch quickly...same in 2nd, 3rd...
    any ideas? Thanks
    robby's Avatar
    Dec 2003
    West yorkshire
    455
    clutch on way out?
    engine mounts loose/ worn?
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    what are the signs when the clutch is on the way out?
    btw, if I press the throttle more and then slowly release the clutch, it doesn't happen...seems to be near the wheels. or under the engine bay
    I even thought it was wheel alignment/balance;had it all checked.
    Jan 2005
    Colchester, Essex
    147
    Sounds like flywheel symptoms! Have a search there's loads of info on here about them...HTH
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    yeah, i've read somethreads about the flywheel after I posted this one....
