JMB RetrofitsChris Nott
Thread: Error N249
    oversteer's Avatar
    Aug 2007
    23
    Error N249
    Hi everyone, please help... getting this error with my vagcom.. cleared it but it keeps coming back...
    17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
    P1200 - 35-00 - -
    I have checked the dv and its fine... i have the forge 007...
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Have a read of this thread, my guess is you need to replace the actual N249 valve:
    engine bay tidy up?
    D-Tech Performance's Avatar
    D-Tech Performance - Dom
    Jun 2007
    Huddersfield, W.Yorks
    161
    bingo i have a spare if you wish.. mine was removed a while back.. you can also remove the code by use of a correctly valued part
    Jul 2005
    2,488
    If the DV is 100% then its an air leak or broken N249 then I guess?
    oversteer's Avatar
    Aug 2007
    23
    Thanks for the feedback guys, I would like to take it off your hand D-Tech Performance but I reside in South-africa...
    What did you want for it? ($)
