Volks AutosEM Tuning
Results 1 to 33 of 33
    Feb 2007
    81
    engine bay tidy up?
    hi guys, i have a valve with lots of vacuum pipes going to it on top of my rocker cover, on my old ibiza cupra this was a n249 valve with resevior that was removeable as you could bypass it , can i do the same with this valve as it looks such a mess, it doesnt look the same valve on my s3 though? thanks guys. daz
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Are you taking the piss? If you're talking about what I think you are it should be under the engine cover anyway so who cares if it looks like a mess, it's there for a reason.
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Quote Originally Posted by 20vtdaz
    I guess you talking about the vacuum resevior on the top? Yes you can bypass it just the same. Removing it also allows you to remove the bracket that's on top of the coilpacks, which apparently helps them from overheating and blowing.
    [/sarcasm]
    Feb 2007
    81
    Quote Originally Posted by god_thats_quick
    this is a well known mod you idiot! jabba even do it after fitting the ihi kits! so if you dont know what your talking about dont reply, very brave of you getting gobby through your pc by the way! my main point was is this the same valve, what a waster you are!!! and thanks chris for your reply
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    I know if too, and its very common.
    However, there does seem to be mixed reviews on Vortex, a lot of people say it makes no difference...
    <Insert meaningless geeky specs here>
    Feb 2007
    81
    im not after any gains i just think its such an eye sore! very untidy looking, i know loads of people have done it, its just that mine looks slightly different from the SEAT cars that ive seen done but im guessing its the same valve?
    Feb 2004
    2,036
    Jabba leave them on with ihi on s3.
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    I seen it on a few SEAT's and it looks tidy afterwards to! I found a guide on a SEAT forum a while back! Fairly straight forward job, by the looks of it!
    Will try and find the guide!
    J
    Feb 2007
    81
    right, i believe this is the guide you are talking of and inside it also includes removing the secondary injection and combi valve http://forums.vwvortex.com/zerothread?id=3111538
    Feb 2007
    81
    Quote Originally Posted by simch
    how sure are you of this and do you know why?
    it does look so much better gone though doesnt it?
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    This is the guide I found, hope its some help!
    http://www.seatcupra.net/forums/showthread.php?t=42406
    J
    Feb 2004
    2,036
    I'd say I am pretty sure about this.......I took it off for a plug change on mine yesterday!!! lol
    Physically it can be removed but there is a reason for it. Belive its so the n75s and n249 are always operateable even if the motor dies or is not running.
    Maybe they leave it on as a safety feature, but its definately on mine!!
    Jun 2004
    Crowthorne, England
    2,512
    Nice reply I do actually know what it's there for and it IS there for a reason. PS if you care what your engine looks like, you bought the wrong car.
    If you look back at my reply and then your response I think you'll see who the gobby one is, oh by the way, I'll happily tell you what I think in person just as much as I will on here.
    Jun 2004
    Crowthorne, England
    2,512
    Just incase anyone else is reading this and thinking it's a good idea to start choping away, the below is the charge air system works on an S3 with a secondary air system.
    In that guide on the seat site they are talking about removing number 21 (the N249 valve) and number 14 (the reservoir), both of which, in my opinion form quite an integral part of both the secondary air system and the boost control system (from a safety point of view anyway). I would say if you're going to do anything remove the whole lot as per the vwvortex link, but then you might fail your next MOT unless your cats are hot when they do the emissions test and you might get the added bonus of fault codes etc.
    PS, the reason I started looking into this last week (as it happens) is because either my N112 valve is buggered or I've got a vacuum leak somewhere.
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    You're being a bit over dramatic, its a very common mod and no ones engine has spontaneously combusted yet.
    Jun 2004
    Crowthorne, England
    2,512
    Which bit am I being over dramatic about? I don't remember saying the engine would go bang, however after already paying for one new engine myself I have no inclination to remove any safety feature that Audi may have added.
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    If you understood how it works, it NOT a safety feature.
    Its a compression/vacuum reservoir used to enable quicker opening and closing of the DV.
    That said, the pipework created a bottleneck and it actually doesnt fulfill purpose. Its pretty simple to figure out when you look at a working diagram.
    Go read the Vortex thread, I'm sure that will allay your fears.
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    I think someone should try this mod........
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    LOADS of people have - as per Vortex and SeatCupra.
    Makes it tidier, limited gains if any.
    Dec 2006
    N.Ireland
    369
    I had this mod done on my last car.. the difference can be felt, car felt more responsive IMO
    Jun 2004
    Crowthorne, England
    2,512
    Quote Originally Posted by Dave_Bayern
    Firstly, I don't have any fears because I'm not interested in making my engine look nicer as it's just about the most ugly one I've ever seen, secondly I'd rather drive it than worry about what it looks like under the bonnet.
    I'm pretty sure I do understand how it works, and to my mind this does take a safety function, all be it a limited one. Please correct me if I'm wrong here, but does the N249 valve not allow the ECU to control the diverter valve directly?
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    You are not wrong that is what it does.
    But it then means you are adding a mechanical AND electronic bottleneck to a system that was designed to use mechanical means only for operation.
    If we assumed that Audi did everything because it was better in later models, how come the original AGU engine is still the strongest available?
    Jun 2004
    Crowthorne, England
    2,512
    I thought the APY engine was meant to have the strongest internals of any of the 1.8T engines, or do you mean overall reliability? To be honest I don't think they're that reliable anyway, however the most annoying bits aren't even made by Audi so I get that's not all their fault.
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    The AGU has the strongest internals.
    Large port head, stronger forged rods (rest are cast) and 20mm pins.
    BAM also has forged rods, but only 18mm pins.
    Jun 2004
    Crowthorne, England
    2,512
    I understood the APY also had 20mm pins from everything I've seen on the subject. Granted it does have the small port head. I also believe all the 210+ bhp engines had forged rods, however it was ages ago when I was actually bothered.
    Wish I'd had a closer look when mine was in bits now.
    Feb 2004
    2,036
    You dont want to shock load IHI bearings though!!
  28. #27
    Feb 2004
    2,036
    My Bam has 20mils!
    Someone reckoned they had a BAM with 19mils in, not heard of any 18s!
    I belive some of the very early BAM motors had 19s.
    But motors specs is confusing, as people what the reckon the CR is on the various motors to see how much confusion there is!
  29. #28
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    My Bam has 20mils!
    BAM and AMK have 19mm gudgeon pins, cast rods, and forged pistons.
    [/sarcasm]
  30. #29
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    So not as strong as 20mm pins, forged rods and pistons?
    Hence the majority of silly power BT's certainly on the VW side are running AGU.
    Mind, the lack of MAP sensor, large port head and simpler controllers probably helps too.
  31. #30
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Yeah Dave, AGU and AGY are the better engines for a BT conversion. Not sure about the forged rods - never heard of that before. Then again, I don't follow the MKIV scene.
    [/sarcasm]
  32. #31
    Feb 2007
    81
    if you knew all this why reply so negatively? i asked a simple question, but thanks for your further reply's, and to everybody elses replys, anybody going to be brave enough to try it?
  33. #32
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    plenty do it on the 30v biturb i'm going to do it
    just a little a6
  34. #33
    D-Tech Performance's Avatar
    D-Tech Performance - Dom
    Jun 2007
    Huddersfield, W.Yorks
    161
    Quote Originally Posted by ChriS3
    ours had 20mil.. amk lump?? think its pretty luck of the draw myself on these
    amk/bam forged pistons but cast rods and small valve head
    agu cast the lot large port head
