JMB RetrofitsBadger5
Results 1 to 36 of 36
Thread: Our S3
    D-Tech Performance's Avatar
    D-Tech Performance - Dom
    Jun 2007
    Huddersfield, W.Yorks
    161
    Our S3
    Rather than regurgitate the thread i thought id drop you a link to what we've been and are up to with the s3....
    http://www.edition38.com/forums/inde...howtopic=98549
    more updates day by day...
    Jun 2007
    161
    sod it ill copy paste the bits and bats might get a bit broken english as theres thread in between but gives you an idea..
    Thought id chuck it up as am stuck in the office 2001 Audi S3 210 AMK
    going to try get some of it done for detailed show at end of the month but my moneys on too much work and too much eating pie to get owt done lol
    Pics
    some pics of the new cooler minus hardpipes..
    seen as i havent been arsed to update the thread in a while thought id get back on track...
    well the clutch went @ pod hence a comedy 15.9 run LMAO will i ever live that down...
    so in went a stage 1 organic clutch along with a new slave cylinder, master cylinder and a new passenger front driveshaft just for good measure...
    so on with some more intresting bits..
    it was about time i got my arse in gear dropping the car a bit so i thought id go for a basic opener to see what difference some springs would make..
    -30mm eibach vs std s3 rear
    took a couple of hours but the end result (this pic is after 800miles)
    as the new clutch has gone in it bites a little harder so i thought id combat the roll with a polybush an excellent mod to all g4/tt/a3
    around 20mins all in to fit well worth the effort
    also added a bit of silicon and carbon
    a few more pics....
    inside
    one of my own hand made custom exhausts
    pic now sus has settled a bit more and theres 15mm rear spacers im dieing for the new rims to arrive
    some new bits ive been doin (not that many are intrested but helps me blog lol)
    decided to get a few interior bits sorted
    so added a momo top power 300mm and a richbrook knob
    then took a trip to SG Styling (Unit One Long Close Works, Dolly Lane, Leeds, LS9 7TU.. 07836368971)(cheers for the tip VICK) to get some trim work done as the interior was a bit drab IMO so got him to cover the pillars and the armrest make me a new gaiter and do me engine covers.. went for alcantra as something a bit different to leather and in the timescale i gave it was a case of what was in the workshop..ill let you see the pics will be off back there soon for headlining bits of the dash doing and some new front seats
    as my tints were starting to look worn and passenger side was missing from a break in as it turns out they were blue (i never noticed) and sh*te quality so out they went and in with new big up to Kar Cosmetics in Bradford (01274-572000) for persevering with the bloomin sticky stuff.. awesome job
    off to belgium tomorrow but when i get back next stop will be to CAV @ Pure Detail then the bloomin lumps coming out for some forging...and maybe some new rims
    gratuitous part shots
    Brand new GT2871rs
    Mid Way through the strip the strip down...
    Haltech/Innovate Logging AFR Meter
    E-Boost Digital Boost controller
    Turbosmart Fuel Pressure regulator
    and
    new turbosmart recirc valve
    even more new bits collected tonight in a hectic truck blast as theres waiting lists on everything i decided to buy second hand new stuff to get the build in motion
    so picked up 4 of these pauter bad boys
    and 4 of these wossners
    so the bottom end should be together this weekend although ive got a stand at festival on sunday
    but need to tidy up my sump due to its bashed up nature going to plate the bottom for strength and look into baffling it best crack the ally welding gear out
    Jun 2007
    161
    Engine Spec
    1781 cc Std Bore Stroke 8:5:1 comp ration
    Garrett GT2871rs
    D-Tech Tubular manifold
    D-Tech 3" Downpipe
    D-Tech 2.5" exhaust system
    JNL/D-Tech Stage 3 Ported and Polished Head
    D-Tech Inlet Cam
    D-Tech Customised Enlarged Inlet manifold
    SfS/Forge Hoses
    3" MAF Sensor
    650cc Injectors
    Turbosmart 800 Fuel Pressure Regulator
    Turbosmart E-Boost 2 Boost controller
    Haltech Wideband AFR/Lamba Kit
    D-Tech Modified "Thickened" Sump
    Forge Carbon Engine Cover
    Forge Polished Caps
    Pauter Machine Shop Chromoly Rods
    Wossner Low Comp Forged Pistons
    ARP Bolts Throughout
    D-Tech Front Mounted Intercooler
    Mocal Oil Cooler
    Goodridge Hoses for turbo lines and oil lines
    D-Tech Custom Mapped Stock ECU.. to be upgraded to haltech stand alone later
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Oh nice!!!!
    Your intercooler looks like mine, whos is it?
    <Insert meaningless geeky specs here>
    jesters3's Avatar
    The Shire's
    1,516
    nice to see all these additions. Admittedly surprised by how low it is on the Eibachs, i take it you are running 18" RS6s'? Not sure about the alcantara not to my taste still each to their own put am interested in where you will hook up the gauges.
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    Jun 2007
    161
    Quote Originally Posted by Dave_Bayern
    Oh nice!!!!
    Our own a guy down south makes them for me then we fabricate up the pipes...
    cheers dave power ahoy!
    jesters3 - guage mounts and hook ups ill show in time, ai im hit and miss on the alcantra but it looks good in life so am happy... yes its on 18" rs6
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Actually, looking at it again yours is smaller, and shinier.
    That sounds wrong ;-)
    Jun 2007
    161
    Steady on
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    so to say you live so close to me Ive never seem that S3 lol oh well will know what to look out for now.
    red to red black to black blue to bits
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Looks like its coming on well mate
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
    Boydie
    very nice mate - so whats the power output?
    Jun 2006
    712
    you say this is an easy mod, is this the dogleg bush everyone goes on about? where abouts is it located, and how do you go about changing it?
    cheers
    nick-barnes07's Avatar
    Jun 2007
    gloucester
    550
    it located on the engine on the bottum of the car , you cant miss it ,
    Jun 2007
    161
    Quote Originally Posted by fingermouse
    ill pop it round when its rebuilt if ya like i could probably throw a stone to your street from my house lol..
    Jun 2007
    161
    Quote Originally Posted by Boydie
    i wont know exactly till its running and mapped but id be dissapointed if it doesnt make fair bit over 400.. i have a figure in my head but my lips are sealed til i see what happens
    cheers for the positive comments guys
    Jun 2007
    161
    Quote Originally Posted by jonS3
    cheers
    very easy jack front end up.. on s3 (cant remember on others) theres a little brace accross the subframe thats boltable its above that! to fit simply remove that mini brace and undo the bolt out the gearbox end then the two at subframe end. Then take dogbone out, once out undo the bolt on the dogbone (self explanatory as its only one pull off rubber and replace with poly then reverse the process
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,318
    i thought the GT28RS was only good for about 330bhp max though? or is the gt2871RS something different to the turbo chriS3 is running?
    awesome stuff mate, going all out with the forged internals and everything!
    Feb 2004
    2,036
    The motor build will be interest but sorry to have to ask....what were you thinking with the interior mods......!!
    Richbrook ally gear nob.......its not 1996 you know!!
    and the alcantara light grey pillars look a bit odd IMO wiht the black headlining.
    Oh, and the sunvisors look like your granny did them, look at that seam visible in the photo....!
    Steering wheel......eeek
    The one thing you cannot really fault audi for on most fof their cars is the interior........a few subtle additions maybe but I dont like what you have done there at all!!
    Also, your intercooler looks awfully small for a 400+hp BT tbh? You sure that will be big enough?
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Smaller intercoolers run fine on 450+ in Cali, so I'd imagine that'd be OK.
    Mind, it depends how efficient the pipework and core is. If you have a forge, then it needs to be bigger than the air condensor to actually make the intake temps colder, but throw some decent pipework into the mix and you can get away with very small cores. I've seen figures from cars with this size core sucessfully running high HP figures.
    Jun 2007
    161
    Quote Originally Posted by Prawn
    that turbos capable of just under 500 according to calculations its all about exhaust housings etc
    Jun 2007
    161
    Quote Originally Posted by simch
    LMAO not one for subtle opinions?
    imo the audi interior is very drab and needed a lift the rest of the headlining is being covered after edition38. Visors if trimmed will always have a stitch line otherwise you cant cover them. Richbrook ally gearknob = much cheaper than a new s3 one as it was well worn that and it was on the shelf. Wheel its all about euro style mate some get it some dont one thing to have an opinion another to slate.
    And yes the cooler will be plenty large enough
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    Very nice work mate, seems like you're on the right track , got any more vids or pics of the car?
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
    Jun 2007
    161
    will have some more on monday as im going to get on with some more work on it (got vw festival this weekend). IIRC tom_s33 on here has some videos of it when it was running 276
    Jul 2007
    15
    Love the car ... exhaust?
    I love the car and your work! What benefit in terms of bhp would I get with your exhaust and tubular header? I have a stock car, non-chipped. Also do you sell that alloy gear knob, its neat and mine is worn. How easy or difficult is it to replace.
    By the way I am looking for a set of 18" RS6's to replace my 19"ers. Are yours for sale?
    carbster09
    carbster09@juno.com
    thats me
    Sep 2004
    west yorkshire
    3,762
    Quote Originally Posted by D-Tech Performance
    ok see you soon .............. just remind me not to race you if I see you out and about lol
    Jun 2007
    161
    different.. larger housings and different internals turbo is capable of over 400
    cheers will keep everyone updated as things progress
  28. #27
    Jun 2007
    161
    Quote Originally Posted by carbster09
    carbster09
    carbster09@juno.com
    the 18s are staying im afraid daily wheels exhaust wise we saw a gain of around 8-9bhp over stock (awaits esthree) on rollers @ blackpool.
    Header wise for the fitting times etc a map would prove a wiser investment for the cost. Replacing the header (manifold) to an equal length one would equate to around a 15bhp gain.
  29. #28
    Jun 2007
    161
    racing on public roads is illegal
    will do mate
  30. #29
    Pat
    Dec 2006
    512
    Dom,
    Still waiting on a pm regarding exhaust matey,,,
  31. #30
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    Looks good,
    but please change the steering wheel back to the audi one, it reminds me of max power
    otherwise, everything else looks good
    ~ ~ ~2003 Audi S3 BAM ~ Ming Blue ~ 18" BBS Alloys ~ Heated Black Leather ~ Forge DV ~ RNS-E ~ denison ipod link~ parrot mk6100 bluetooth ~ ~ ~
    Still need Remap
    2007 Audi S3 8L
    2005 Audi A3 1.6 sport grey with climate control
    2003 Audi A3 1.6 sport black without climate contol
  32. #31
    Jun 2007
    161
    Quote Originally Posted by Pat
    Dom,
    sorry mustve missed it mate ill look in pm box in 2mins
  33. #32
    Jun 2007
    161
    Quote Originally Posted by rickparmar
    Looks good,
    nah mate the wheels staying i thought some of the styling would be not to you guys tastes audi one is a bit big for me and a wee bit bland must be the inner boy racer breaking out
  34. #33
    Jun 2007
    161
    more updates;
    this is taken from a post on another forum by a friend..
    Final results is ported small port head has a 4% gain over the exhaust side of a big port when taken over the whole range with an increased average velocity for quicker spool up. The intake gains 5.1% across the full lift range over the standard big port head again a noticeable incresease in velocity which should give you stable afr readings on your mapping. Long and short you got hp capabilities exceeding a big port with torque and throttle response of small port. Can't really go much further on the intake side of things as you are already exceeding the flow capability of the small port intake by over 12% at peak lift which should hopefully be helped (counteracted by) with the increased volume plenumb chamber you are running.
    Anyways here's your picies as promised
    Close up of your heads surface
    Exhaust port
    intake side
  35. #34
    Jul 2007
    85
    How about the oil cooler.
    Do you have any pictures of it ?
  36. #35
    chrisnic0's Avatar
    Jan 2007
    Chester
    38
    Wow the engine mods look amazing, i wish i could pretend to know what half of them are. Thats one tuned S3!
    Im also liking the interior think its an def improvement.
    Keep up the good work
  37. #36
    jeffers999's Avatar
    got boost
    May 2007
    pontypridd s/wales
    390
    Hey mate that looks nice the cooler looks close to mine http://i151.photobucket.com/albums/s.../aaaaad006.jpg
    im liking the leather gator around the gear knob too where did u get it done ?? cheers jeff
    1999 audi s3, silver recardo leather, lightly smoked windows,18" rs4 reps, full exhaust with de-cat, cold air induction, front mount intercooler, 13.850 1/4 mile @ 102 mph.A little vid on me running a 13.90
    http://s151.photobucket.com/albums/s...t=MOV00019.flv
    xbox gamer tag jeffers999
    PS IM AFTER A CENTER ARM REST ASAP......
    Car collection
    Audi s3
    Vitara fat boy jeep soft top
    saxo vtr , little track toy
    polo 1.4 beast
