Hi brake pad warning light came on this morning!! Wheres the best place to get them from or fitted? Not too worried about fancy ones(pads) any recommendations for replacements?
Go to a local independant garage then, if you don't know where to start looking, why trust yourself with something that done wrong, results in death. Probably your death....
when the light comes on you still have a lot of meat left on the pad so dont panic. Also have a quick look at them yourself as the wire may have just broken.
I may well check the wire as the guy I brought it from said he had them done not too long ago and the mate (mechanic) I took confirmed this!! is it a common fault?
if the pads are fine then you can just short the cables together to turn off the warning light.
ive not got round to it yet but will probably change pads soon anyway
