EM TuningVolks Autos
Results 1 to 17 of 17
    Effect's Avatar
    Apr 2007
    Derbyshire
    469
    calling S3 owners
    At idle (i think when warmed up) the engine is not sat at a certain revs it hunts up and down, only very slightly BUT this causes a ever so slight vibration that can be felt through the seats.
    Is this normal, if not what is the likely cause. I was thinking a dodgy MAF could cause it.
    s3ollie's Avatar
    Jan 2007
    749
    mine does this hunts a tiny bit, hardly noticable.
    Slick S3's Avatar
    Dec 2006
    120
    mine too
    S3 210bhp, facelift, black, 18" RS4's, heated electric leather recaro's, light tints, arm rest, electric sunroof.
    Jun 2007
    north yorkshire
    41
    Mine does it as well i posted simalar thread a few weeks ago, mine hunts between 660 rpm and 720 rpm dont sound a lot but u can feel it though car. The rpm figures r from the read out on climate control display.
    52reg s3 black. Need a pair of them aluminium doors mirros there the dogs.
    Jul 2007
    Huddersfield
    218
    mine does this but without the vibration.
    On my clio 172 a few years ago the vibration was the exhaust middle section not sealed properly to the cat
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    is your air con switched on this will always cause the engine to hunt or idle irratically but slightly. anything else could be throttle body, air filter, MAF.
    S3 - Gone but not forgotten!
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Or proper vibration that actually reverberated through the whole chair, then flywheel as the dual mass ones are cack..
    <Insert meaningless geeky specs here>
    Aug 2007
    199
    My RPM needle hovers around a bit too.
    Feb 2007
    24
    This can be caused by a vacuum leak. Check all your vacuum hoses for tears.
    nick-barnes07's Avatar
    Jun 2007
    gloucester
    550
    mine done it as well ,
    Jun 2003
    west yorkshire
    90
    mines been like it from new
    RS4 B5 380bhp
    Feb 2007
    549
    mine does it too,
    Effect's Avatar
    Apr 2007
    Derbyshire
    469
    To all that have answered that yours does it to.
    Can you feel the vibration through the seat when sat in it ?
    The only reason I ask is I had a 306 that did this once when the cambelt let go and a couple of valves got bent ever so slightly and ended up with me having to sort it.
    mastayoda's Avatar
    Jun 2007
    86
    mine does this too, and i was hoping changing my knackered maf may sort it, and although its sorted my poor fuel ecconomy it still does it. it doesnt judder but you can tell it does it.
    Jun 2007
    22
    Mine hunts a bit, but no vibration.
    D-Tech Performance's Avatar
    D-Tech Performance - Dom
    Jun 2007
    Huddersfield, W.Yorks
    161
    also can be VVT solenoid then you get a rattle from the head as chain end up slack
    Bellic's Avatar
    Dec 2006
    253
    mine do does it aswell it is like a slight missfire blip then goes ok , car does go down in revs when aircon is on sucks quite a bit of power from the engine very noticeable when pulling away.
