Volks AutosBadger5
Results 1 to 10 of 10
    Jan 2007
    Hertfordshire
    520
    Starting Problem...
    Hi, this isnt actually my car but my dads. the car seems to want to start turning over, but not actually starting, seeming as though it has fuel starvation or no spark. The engine judders then stops as though its about to start. Any idea chaps?
    s3ollie's Avatar
    Jan 2007
    752
    immobilizer?
    Jul 2005
    2,488
    what engine?
    Jan 2007
    Hertfordshire
    520
    I thought immobilizer too but no light comes on... Same engine as mine I think (AGN?) Its naturally aspirated in any case... Could it be the fuel pumps had it? How difficult are they to change, I'd rather take all the steps I can to get it working myself without resorting to the garage.
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    same sort of thing happen to my girlfriends fiat but it just turns over and doesnt fire,i found a crack in the inlet manifold and thought that it may be drawing in unwanted air,so welded it up and still the same,i have checked everything i can think of engine wise,i doubt its the fuel pump,im guessing its the immobiliser,which i am goin to a dealer so they can put a diagnostic computer on it and see if they can reprogram the immobiliser.etc.
    joshW's Avatar
    Feb 2006
    S.Wales
    266
    I had this problem for the last few weeks, was starting sometimes and not others, turned out to be the crank sensor!
    Dont go on my word though as the little bloody sensor was 68+VAT!!!!
    get a diagnostic!
    josh
    Jan 2007
    Hertfordshire
    520
    Thanks guys, I'm gonna have a go at it tommorow during the day I'll let you know. So far we have Fuel pump/immobiliser/crank sensor... anymore suggestions? As many educated guesses as possible would help as it allows us to eliminate them as we go!! Muchos Gracias!
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    can you smell petrol in the exhaust? could be the temp sensor has failed causing it to pump in too much fuel which floods the engine, try disconnecting the sensor and cleaning the plugs
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    have you checked the battery?
    Jan 2007
    Hertfordshire
    520
    I have checked it just in case but its definatly not the battery since it turns over... It seems like its about to start then judders and stops. Just had a look today and it does look like the fuel pumps had it. Is there a fuse for the fuel pump?
