EM TuningJMB Retrofits
    Audi S3 (2000)
    Mar 2007
    303
    break light help
    Hi guys,
    while messing with my coil issue i noticed that my break lights dont work at all.
    i had an issue a few months back where the warning light came on so i swapped the bulbs (but the tailgate one worked fine)
    now nothing works and no warning light. if i remove the bulb i get a bulb warning light, not the break warning light.
    whats it likely to be / worth my trying? new break peddel switch?
    Jul 2007
    Huddersfield
    218
    fairly certain its the break pedal switch
    Audi S3 (2000)
    Mar 2007
    303
    Quote Originally Posted by steebo888
    Thanks ill pick one up
    we tested with a meter
    one set of contacts was normaly open the other normaly closed. but dunno if thats right!
    Oct 2005
    England
    101
    i had the exact same thing after i replaced a filament.
    Mine was the brake light switch was cheap and easy to do.
