Volks AutosChris Nott
    Jan 2004
    Aberdeenshire
    26
    ESP Warning Lamp
    Every so often, the ESP warning lamp illuminates when I start my car from cold and stays on, which would indicate some sort of fault to me. The lamp goes out if the engine is stopped and started again.
    My dealer had a look at it, but said that there were no faults recorded.
    My warranty is due to run out this year, therefore I would prefer to get this fixed before then, therefore has anybody else experienced a simillar fault? Is so, how was it rectified?
    Jan 2004
    Aberdeenshire
    26
    Re: ESP Warning Lamp
    My car was back at the dealer again today to fix some other things, therefore I requested them to consider the ESP fault again.
    Consequently, the service report sates that they carried out a 5051 test which has identified a fault with the YAW rate sender. [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Anybody know what a 5051 test is?
    Anybody know what a YAW rate sender is?
    Anyway, another YAW rate sender has been ordered, so it will have to go back to get that installed. [img]/ubbthreads/images/graemlins/snore.gif[/img]
    chimmo's Avatar
    Nov 2003
    Cambridgeshire
    59
    [ QUOTE ]
    [/ QUOTE ]
    Hi RAS,
    Not being a techie in the mechanics dept, I can't take the credit for this info, but found a top site that explains what the YAW rate and detector is Yaw Rate Info
    The YAW rate sensor "determines how far off-axis a car is "tilting" in a turn. This information is then fed into a microcomputer that correlates the data with wheel speed, steering angle and accelerator position, and, if the system senses too much yaw, the appropriate braking force is applied". [img]/ubbthreads/images/graemlins/shocked2.gif[/img] Clever stuff...!
    I can't tell you much about the 5051 test but it seems to be the standard Audi diagnostic and fault finding tool.. [img]/ubbthreads/images/graemlins/blush.gif[/img] I'm sure someone will be able to provide a more detailed explanation of this test..
    Hope this help?
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Apr 2003
    England, North West
    425
    YAW
    I would suggest its senses the car going into a spin ...
    Drill's Avatar
    Land of Good Beer, and better Roads :-p
    928
    chimmo, nice looking car mate [img]/ubbthreads/images/graemlins/grin.gif[/img] Denim ROCKS!!! [img]/ubbthreads/images/graemlins/angel.gif[/img] [img]/ubbthreads/images/graemlins/groovy.gif[/img]
    As for the 5051, it's just the diagnostic "Computer" (for lack of a better term).
    chimmo's Avatar
    Nov 2003
    Cambridgeshire
    59
    Hi Drill,
    It sure is Denim [img]/ubbthreads/images/graemlins/dancing.gif[/img] Couldn't not buy it when I saw it, such a great colour... the car's not that bad either [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
