JMB RetrofitsChris Nott
Page 1 of 2 12 LastLast
Results 1 to 40 of 50
    nick-barnes07's Avatar
    Jun 2007
    gloucester
    550
    took the baffle out of my turbo charge pipe
    took the baffle out of my oem turbo charge pipe earlier as i had to fit a new lamnda to my downpipe , and it made a noticable difference , seems like the car spools up a bit quicker and there is a deeper note to the exhaust on full throttle , dont know if it has been posted before so i thought i would post it , definately worth doing , only took me 20 mins ,
    nky_84's Avatar
    Oct 2005
    Edinburgh
    433
    Why is the baffle in there in the first place? It surely has some function?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    wheres the baffle and is it easy to do?
    Jun 2007
    gloucester
    550
    i think the baffle is in there to restrict the noise a bit , there are plenty of bits on cars that can be modified , the baffle is at the top of the turbo intake pipe where it gets bigger , you have to cut it out ,
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    cut it out is there any side affects that could happen, and is it replaceable if i messed it up?
    Jun 2007
    gloucester
    550
    the baffle is not replacable , but the charge pipe is , places like mij performance and gt tuning sell chrome charge pipes without the baffles in ,
    Jun 2007
    gloucester
    550
    there are no side affects i would of thought , better air flow ,
    ash_s3's Avatar
    Aug 2006
    Shrewsbury
    1,005
    You mean the metal boost pipe not TIP, the TIP is made from rubber and goes from your airbox -> turbo
    2001 Audi S3 l MTM Remap l 252.7bhp 432.4Nm l Forge 007P l ECS Porsche Stage 2v2 Front Brake Set-up l ECS Stage 1 Rear Brake Set-up l 18" RS4 Alloy Wheels
    Jun 2007
    gloucester
    550
    no not the tip , the turbo intake , that is metal ,
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    Its called a Charge Pipe isn't it?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    the metal pipe chucks air to the intercooler so i would say its a charge pipe not a intake, it ain't taking anything in, the intake is the rubber pipe from the air box
    Jun 2007
    gloucester
    550
    Quote Originally Posted by Aky
    yeah , keep getting them mixed up , changed title now ,
    Jun 2007
    gloucester
    550
    Quote Originally Posted by sandip
    it definately made a difference when i took the metal baffle out ,
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    had a look today, how did you cut it out? what did you use? easy to take everything apart just wasn't sure how and what to cut it with
    Jun 2007
    gloucester
    550
    my mate done it with a air line , and a saw that run of the air line , took him less than 20 mins , you would be there all day if you were to do it by hand
    fazzybear's Avatar
    May 2007
    Brighton
    Nick if it aint too much trouble do you reckon you could take a snap of your fine work
    cheers m8
    2000 S3, SILVER, FULL HEATED LEATHER, 18" RS4, MILLTEK, FORGE RE-CIRC , CC REMAP
    Stewart's Avatar
    Feb 2005
    Blackpool, UK
    696
    Yes, a how-to with pics would be excellent!
    Rarrrr! I'm not Lesdyxic!
    There are three kinds of people in the world, those who can count, and those who can't.
    Clicky Here!
    Oct 2005
    England
    101
    Ok i've just done this mod.
    Beginners BEWARE this mod its not easy with the incorrect tools .... infact it quite brutal.
    I used a hacksaw, 2x drill bits one long bout 5mm and one 3mm short, a hammer and a chisel.
    Check out the pictures.
    What you need to do is cut off the very edge of the end lip only about 3mm so that you leave the lip remaing for the clamp.
    After that the baffle lip will show, hammer this off ... its cast alloy and breaks easy. Then you need to drill down the baffle frames (this will make sense when you there doing it) drill down at half inch spaces all around the pipe to weaken the baffle frames. BECAREFUL not to drill the side of the charge pipe!
    Then pretty much just break it to pieces with the hammer and chisel.
    Hope this helps ...... im off to test drive now. Will post back later with what i expect to be insignificant results.
    ps pictures were with cam phone so not the best
    Oct 2005
    England
    101
    Performance Increase ......... Na i dunno possibly a small amount, the car did seem fast today.
    So the VERDICT: if your bored and want to fill in a couple hours then go for it, your may gain a little ..... and every little does add up i spose.
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    would filling the baffle holes with a chemical metal work? instead of completely butchering the pipe, or would the heat be to much as a product i know (JB weld) says its stable at very high temps.
    what you lot think?
    S3 - Gone but not forgotten!
    Oct 2005
    England
    101
    no way man filling in the holes restricts the pipe size
    i should have taken a pic of the finished product cause its not butchered at all it came out well looks completely oe inside.
    all i was saying is that your have to be a bit of a butcher to get there.
    get it done you'll see
    s3ollie's Avatar
    Jan 2007
    749
    can you imagine if some chemical metal came loose and got into the engine
    Oct 2005
    England
    101
    Yeah nasty! Guess i should have mentioned CLEAN THE PIPE before installing. I used carb cleaner and the hose to wash it right out, then left it to dry before putting it on my car.
    Really you would have to be stupid to put it straight back on with out cleaning it though!
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    What a completely pointless mod. When did AS.net become chav central :-)
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    You'll get a fairly evil roar off the charge pipe when you've removed the sliencer.
    I did mine years ago and smoothed out and polished the insides...and when running 1.85+ bar boost, it gave a really evil rushing-air type sound.
    Can't say I got a gain out of it either...
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by HTC
    I don't think it's pointless...
    But only if you are really pushing the limits of the K04.
    Removing any restrictions in the charge pipework (removing the sliencer/restrictor from the chargepipe, fitting better flowing ICc, smoothing out the TB etc) will add up to giving smoother airflow and less pressure drop / better throttle response in high boost applications.
    A lot of work for a little gain though...unless you really are pushing the limits of the K04.
    Please note:
  28. #27
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Each to their own. Surely removing the baffle leaves a pronounced step in the pipe where is used to sit.
  29. #28
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Two steps really...
    The air opens up to fill the chamber, then has to squeeze back into the pipe size...although it does that standard as the silencer is perforated.
    Opening up the resonance chamber is what gives the additional noise, I think.
    I see your point about the step though...which is why I smoothed out and polished the inside of the pipe to minimise turbulence.
    Please note:
  30. #29
    Jun 2007
    gloucester
    550
    why is it pointless , it takes 20 mins and is free
  31. #30
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    i've done mine this morning. simple took me 30mins instead of hacksawing the edge i just used my grider and ground off about 1mm and then drilled one hole and the rest just smashed up into little bits! LOL
    seems to spool up quicker but i can't here anymore noise. less of a whoosh more of a groan now. hitting 21psi peak on my boost gauge and sitting at 18/19psi. nice
  32. #31
    Oct 2005
    England
    101
    Yeah it does leave a lip about 4 inchs down the pipe. But on the plus side your opening up the inlet of the pipe by 3/4 of an inch. Over all its got to be better, debatable if its werth the time though.
    and HTC you have got no right to make that comment. All sorts of interesting mods have come up on this web site, some of them good, some of them not it's up to the individuals opinion. Dont go calling people chav's from the comfort of your computer room chair!!
    Especially with a Yellow 1.8t!
  33. #32
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Quote Originally Posted by 242spot
    HTC has got every right to say what he thinks, just as you have.
    I also agree with him to an extent, however not about this thread but there are definately other threads that scream Chav to me.
  34. #33
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by god_thats_quick
    That's the truth...
    I just wish everyone would accept that...opinions are opinions.
    Sadly, that's also the truth...
    The standards are dropping on here...
    Please note:
  35. #34
    Jun 2007
    gloucester
    550
    people have got every right to express what they think on a forum , but it is not a chav mod , putting 20" spinners is a chav mod with a 5" exhaust tip
  36. #35
    Jul 2007
    55
    As with most modifications of this type ie - ported throttle bodie etc . No gains in bhp are ever found but small benifits in throttle response are generally noticed , So considering its free and you have the time i can't see why its pointless but dont expect to much ?
  37. #36
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by stevess3
    I don't agree about the "No gains in bhp are ever found" bit...
    I gained 1.5 BHP peak by porting my 2.0 16v ABF throttle body...swapped it back and forth on the dyno, got 1.5 BHP each time.
    Now I know Dyno accuracy is only a few %...but swapping it in gave 1.5 BHP more, swapping back to standard, 1.5 BHP less.
    I'd say that was a gain.
    Not much...but you do sometimes see gains.
    You put a corrado VR6 TB onto a Golf VR6 and you'll get 3-5 BHP with no other mods.
    Please note:
  38. #37
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    944
    Quote Originally Posted by Ess_Three
    I got a good gain with bored out corrado throttle body instead of stock one on my 2.9 mk2 jetta,golf version is shockingly restrictive,whats that big lump about?
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO ST2 MAP ,MILLTEK CATBACK EXHAUST,PANEL FILTER,034 INTAKE PIPE.
  39. #38
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Ahh...the 'ramps'?
    It speeds up air flow ar small throtte openings to make the transition from closed throttle to slight throttle smoother...but it robs top end power.
    I've removed the ramps from my ABF TB...that was the gain of 1.5 BHP.
    I've done 3 or 4 Golf VR6 TBs...going to a Corrado VR6 TB which is also a different shape (more in line with the airflow) and removeing the small ramps on it gives 3-5 BHP on all the cars I've tried it on....but it feels like much more with it's better upper rev range pulling.
    Please note:
  40. #39
    ANDYTQ's Avatar
    Oct 2003
    944
    I had shrick cams too,so even more rev tastic,Cheers Andy
  41. #40
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Ahh...Dr Schrick's finest camshafts.
    I have dabbled with those in the GTI...
    Please note:
