JMB RetrofitsAH Fabrications
Thread: no 2nd gear :(
    TerryTibbs's Avatar
    Jul 2007
    no 2nd gear :(
    hello all,
    i have a 1.8 se quattro, 99, it wont go into second gear when driving at all!!
    parked without the motor running it will go in no problems at all.
    shift isn't loose, no other problems with the box that i can think of, took it to a local "specialist" who's talking 2k to replace the whole box, is this right?!!
    cheers
    sorry if i've posted in the wrong section
    Stewart's Avatar
    Feb 2005
    Blackpool, UK
    696
    I would try having the gear cables/linkage aligned correctly first. However, bad first/reverse selection is usually an indication of this.
    Having thought about it, it sounds like the baulk rings (synchro rings) are mashed, not allowing gear selection when the mainshaft is spinning (I.E Engine running).
    2k is very steep though, an independent GB specialist should be charging around £600 for a rebuild including main bearings.
    Rarrrr! I'm not Lesdyxic!
    There are three kinds of people in the world, those who can count, and those who can't.
    Clicky Here!
    TerryTibbs's Avatar
    Jul 2007
    i thought it could be the synchro too - got to get back on the phone again then!
    thanks for the reply!
