Monster MotorsportBadger5
Results 1 to 7 of 7
    S3 amd map,coilovers,upgraded heldex,lcr spliter..
    Apr 2007
    Bristol
    228
    car higher on one side
    i fitted my coilovers about a month ago and set the rears on the lowest setting which was not that low if fact.
    one side was about 10mm lower than the other so i thought i would let them settle and see how it looked. well now its settled the lower side is just right on the hight front but the other is still 10mm. now the only restriction to how low the car will sit is the sping or the bump stop.
    so i swopped the springs over and the same side is still higher. any ideas how this is possible?????
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    May have more weight over one side.
    Built in Germany, Perfected in England
    Apr 2007
    Bristol
    228
    cheaky ba%^&*d,
    it is the drivers side but its the same with the car empty,
    baybe i should get some sand bags in the boot...
    Jan 2007
    Hertfordshire
    520
    This is gonna sound a bit lame but do you have a full tank of fuel? If not only thing I can think of is shock springs broken.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,582
    I would check your ARB bushes....
    Apr 2007
    Bristol
    228
    abr bushes are all new as are the abr's, also the shock will not make the car sit high or low as the spring is the thing the car sits on... help
    Jan 2007
    Hertfordshire
    520
    Umm maybe thats what I meant haha mine sat lower and apparantly it is a common problem the guy said the top of the spring just broke and it dropped about an inch id guess he said it happens all the time on VW's?? worth a look surely?
