So are you saying there were or are two cars out there on one reg plate..? One genuine and yours being a fake...? How can this happen..? I can understand it if a write off car is bought, with log book, then straight (ie undamaged) car is nicked and the identity fo it disguised using the write off log book..? But there would still only be one car with that reg, albeit a dodgy car? I can see someone cloning a car for evading speed cameras, etc, but how do you get a legitimate log book for it..? There must have been some colusion with the owner or keeper of the original car with that reg, otherwise, where would they get the chassis number for the original reg...someone must have had access to both cars once?
Also, you say the chassis plate was "fibreglassed in". Was this the origibal car with your numberplate's chassi number, ie a bit of metal cut out of the original car with your number, or was it a bit of plate stamped with the incorrect chassis number..? Could the old other chassis number be seen underneath..?
what about the window" on the screen that shows the chassis number..? did that have the "correct" chassis number for the reg you were driving about on? if so, maybe that was taken from the original car? if it was a different chassis number or missing, then that is more obvious. How have youn got the service book, is it the orginal and does it show the VIN number on the book..? Does that vin match the ones on the car, dodgy plate, winscreen window and the sticker inside the boot..? If they all match up, someone MUST have had access to both cars to get the stickers and book etc, but how did they remove those flimsy paper sticker form the boot..? Oh, the VIN IS on the ECU also, get vagcom to read it and see if it matches. Dont let this one go, if you checked all these things and they all added up, all matched the legit car you thought you bought, may be it is ok, maybe its had some secondhand part fitted to it which came off a broken stolen car and that had the tracker in it..? Long shot but you just never know. If the chassis numbers dont match then you are a bit mullered as they will say you should have checked.
The facelift S3s and A3s have the chasiss number stamped into a "tamperproof" soft metal strip under the window on the plastic scuttle panel cover. Any fo you guys with facelifts,go and carefully lift the window up and have a look at the chassis number that's stamped on there! You will crap yoursleves ands think its fake as it looks like its on a think bit of metal stuck over the original number stamped into the cars metal! Looks so dodgy, I swear if the cops pulled a facelift model over and looked, they would swear it was dodgy!
real sorry to hear about your bad news, but I rekcon it may not be as bad as it seems. You clearly ahve bought somehting, and if is a stolen car and the insurance have paid out on it, what do they want it for now..? Maybe they will let you buy it off them for cheap and get it a legit plate, even if its a "q".
This really does not add up at all.
