Fault codes.
nickaudi41
Hi everyone,
I have plugged old VAGcom in and recieved this fault code.
16497 - Intake Air Temp. Sensor (G42): Signal too High
P0113 - 35-10 - - - Intermittent
Readiness: 0000 0000
I thought it was the MAF but is this right?
I have googled it and no one can tell me what the problem is.
Any ideas?
I have seen this too when my MAF was playing up! Want to plug mine in later, clear the fault codes and try a run? When you clear the fault, does it come back straight away or does it take a couple of days driving?
Yeah that would be cool, can you bring your handy tool kit please?
I haven't cleared the codes yet due to not knowing what is causing it.
Did you get a genuine new MAF then? Also how much did you pay?
Yeah thats the one Nick, you can clean it using alcohol or electronics cleaner. I bought one recently for my A4 1.8T and it cost £30 from the stealers if I remember correctly. Should be a real easy job to do, on mine you just unclip the lead and unscrew the allen-bolt holding it in.
10
3K
6
2K
2K
chazza55
C
