PaulBelsham
Hi All
Had my S3 now for just over a year and have covered nearly 12,000 miles.
After about 10,000 miles I started to notice a drop in performance then not long after, when I was driving down the M1 the low oil warning light came on (I normally check the oil ever time I clean the car, but had neglected it a bit what with the cold weather)
I was 100 miles away from home so had to drive that with the low oil light on, when I got back the car took an extra litre of oil before it was back to normal again, then the performance got better and all was fine.
The question I have is that on Sunday I decided to check it again as I was cleaning it and noticed that the oil was again very low (near the bottom of the oil line on the dipstick but not as low as before) it needed an extra 500ml to get the level ok again. Is this normal ? the dealer told me that in extreme cases that car could burn a litre every 1000 miles until run in, however I've covered 12K so it should be run in by now surely.
Any help/advice appreciated
Paul
Paul
