Volks AutosMonster Motorsport
Results 1 to 34 of 34
    Jan 2005
    Colchester, Essex
    147
    Warped Porsche discs? Opinions pls
    O.K lets start with the fault.
    Under braking from speeds only above 35mph I am getting shaking through the steering. This is not everytime I use the brakes and it varies in it's violence. Sometimes there is no fault but 80% of the time some shaking of varying ferocity is noticeable mainly through the steering, it's bearably noticeable through the pedal most of the time although sometimes there is a slight pulsing feel. There is never a shake under 30mph, and sometimes no shake atall even when stopping from 80+mph???
    I have recently fitted brand new Discs and pads upfront which on mine is a Porka 993 TT 'Big red conversion' so not cheap (about 3000 miles ago). I'm not a track or street racer and due to the capacity of these brakes find it hard to believe i could've warped them? Especially seeings the ones I took off were cracked (previous owner) and delaminating and still gave no shake.
    I've been under the car and checked how they're wearing and all looks good the state of the discs is good with no grooving etc and i've checked all caliper bolts etc are tight. All ball joints and bushes seem in good nick, with the only suspect rubber possibly being a slightly perished but not broken rubber mount for the control arm, this didnt seem to give any excessive play though. However a noticeable bit of play was found in the steering arm where it enters the power steering box! I understand from searching this can be removed by an adjustment on the PAS box, which is on my list of things to do at the weekend.
    Basically Im convinced by the feel its a steering issue rather than brakes! (and due to it's inconsitentcy) But wanted to pick your brains so whilst Im under there I can look for any other possible culprits, before I bite the bullet and pay to have the disks checked for run out also where can I get this done presumably most garages will have the facilities to check?
    Sorry for the long post and thanks for any input, Joe
    EddyH's Avatar
    May 2007
    Pontefract
    60
    I'm assuming the discs are 2 piece so did you replace just the rotors on the existing bells? If so were checked to make sure they were 'true' and balanced? I really doubt they're warped, other possibility is a build up of pad residue in one patch on the disc surface, some hard braking from high speed should clear that.
    EddyH
    Boxster S
    Passat V6 4Motion
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,435
    Are you running spacers to clear the calipers? and are they hubcentric. The bushes on my lower track arms failed on my S3, and this cause my steering to wobble under braking, I thought it was warped disks at first!
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    I have the same problem and I've convinced myself that its the discs. It seems to happen when braking steadily rather than heavy breaking. I have'nt bit the bullet and bought new discs & pads Maybe its the bushes as JoJo mentioned. I'd also like to know everyones thoughts on this rather than blowing money left right and centre trying to get the problem resolved.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,435
    I'm not 100% sure how to test the bushes, but the guys at AmD(a few years ago now) showed me that my front wheels had 1" of play on my front wheels, you could see it moving forwards and backwards with the car suspended on the ramp. It was this mocement that was causing the steering wobble under braking.
    Aky
    Aky's Avatar
    Aky
    Nov 2006
    West Yorkshire
    1,500
    JoJo - so is it a case of getting new tracking arms or is it the wishbones which need replacing?
    Cheers for your input
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,435
    Quote Originally Posted by Aky
    I had both the track arms replaced with facelift items, they are lighter and slightly different shape, but everything lines up was told. Not expensive for the complete arms, something like 25+vat each?, needs 4 wheel allignment after though, so labour isn't your best mate here.
    Jan 2005
    Colchester, Essex
    147
    I checked for pad residue/build up as i also thought this but only found clean shiney discs!
    I do run Spacers and they are hubcentric, i checked and these seemed tight and true in locating into the wheel.
    Also yes the discs are two piece, and subsequently replaced the rotors onto the existing bell. Was pretty careful to make sure the nuts were all tight and true but this is a consideration - although for the first 2-3000 miles all was fine. I suppose getting run out checked on the discs would identify this.
    I'm sure you can feel its worse braking on bumpy roads which would link to the bushes on the wishbones (which were cracked if i'm honest)!
    Jan 2005
    Colchester, Essex
    147
    Just to check we're all barking up the same tree i'm refering to Item 1,4,3 on here:
    http://www.vagcat.com/epc/cat/au/A3/...01/52/2401002/
    Sep 2005
    London
    197
    jojo is on the money, worn lower arm bushes or ball joints can cause these symptoms.
    bouncer--daz's Avatar
    A dog is for life....not just for friday nights!
    Mar 2007
    Gloucestershire
    543
    I am also getting shuddering under braking which is also inconsistant but im currently gettin a knocking noise. Ive just been out and checked the shocks, they dont seem to have gone. I also jacked up both sides and put a bar through the alloy to see if there was any play in the top mounts which there doesnt seem to be. If it were my lower arm bushes gone could this cause a knocking noise? The knocking doesnt seem to happen when going over speed bumps etc... more in terms of bumps on the road surface. Best way too hear the noise is too roll down a hill in neutral. The knocking will be a continuous tapping (imagine driving over a load of cats eyes in the centre of the road - just not as harsh). Input would be welcome!
    Daz - Audi A3 - 18" rs4 alloys - Weitec ultra gt 30mm kit - pipercross panel filter - tints all round - facelight rear lights - clear side repeaters - german style plates - flip out dvd touchscreen hu
    Sep 2005
    London
    197
    Do you feel bumps through the steering wheel? Does it feel 'harsh'...almost like a hollow knock?
    If so that's worn lower arms.
    Mar 2007
    Gloucestershire
    543
    yer im pretty certain I can feeling it through the steering....might have too take her out again in a sec. Just spoke too the audi workshop.... £10 for the bushes or £55 for new complete arms.... after labour charges thats £260ish for the bushes as they have to be pressed in or £270 for new arms. really dont want to be paying that sort of money. Anyone done the job themselves?
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    if you are into diy car stuff they wont be very hard to do, pressing bushes in is hared than new arms so its how good you are as to how hard the jobs is tbh.
    havn`t done the audi but have done hondas and fords in the past for mates.
    red to red black to black blue to bits
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    I believe the bushes require approx 10 ton per square inch pressure to force them in, so its mostly cheaper to get new arms
    <Insert meaningless geeky specs here>
    Sep 2005
    London
    197
    I'm doing a complete front-end suspension freshen up on mine in the next 2 weeks, which will involve the following:
    New top mounts,
    ARB bushes,
    ARB drop links,
    Lower arms,
    Track rod ends
    This is something I tend to do on all cars as they pass 40k, it will tighten up the car to how it was from new. I will do a guide for all this and put it on my site.
    I will follow this up for the rear when I've finished fabricating some adjustable arms.
    Stewart's Avatar
    Feb 2005
    Blackpool, UK
    696
    Quote Originally Posted by mwstewart
    New top mounts,
    ARB bushes,
    ARB drop links,
    Lower arms,
    Track rod ends
    I did exactly this as my ethos was the the same. However, at 46k, the balljoints were like new etc etc. To cut a long story short all that 'really' needed replacing were the drop links and ARB bushes.
    Not a bad thing to do but some things 'may' be a waste of money unless you believe in spending money on placebo effect.
    Rarrrr! I'm not Lesdyxic!
    There are three kinds of people in the world, those who can count, and those who can't.
    Clicky Here!
    Sep 2005
    London
    197
    Quote Originally Posted by Stewart
    For sure, but my lower arms definitely need replacing, I've not actually had a car yet that didn't need them past 40k. I'm not talking MOT pass here but the point where you can feel the handling 'sharpness' has gone off what it once was. I'm a bit of a perfectionist in that respect.
    If the arms are gone then the other components will have wear too, so seeing as the parts themselves aren't expensive, it makes sense to replace everything at the same time.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,435
    Quote Originally Posted by bouncer--daz
    yer im pretty certain I can feeling it through the steering....might have too take her out again in a sec. Just spoke too the audi workshop.... 10 for the bushes or 55 for new complete arms.... after labour charges thats 260ish for the bushes as they have to be pressed in or 270 for new arms. really dont want to be paying that sort of money. Anyone done the job themselves?
    AmD told me the prices would be similar for just the bushes or with new arms, so went for the latter.
    Feb 2006
    Lincolnshire
    714
    The noise you describe sounds exactly like the one I had with worn front ARB bushes an/or worn ARB.
    No noise over speed bumps or other big stuff, but a knocking when going over the usual broken british roads.
    That's where I'd be looking first on yours.
    Audi S3 - 2002MY - Denim Blue - Gone
    VW Polo GTI - 2011MY - Candy White - Here
    Feb 2006
    Lincolnshire
    714
    Regarding the OP, I wouldn't necessarily rule out the discs being warped just because they're Porsche items. A quick search of some Porsche fora will show plenty of evidence of warped discs, even at such low mileages.
    Before you start throwing cash at the suspension arms etc, any competent garage should be able to measure the run out on your discs, and also check they are centred properly.
    I'd do that first, and at least then you can move on to the next thing confident it's not the brakes?
    Apr 2007
    297
    Now i'm just waiting for someone to come along with that article again explaining how warped discs dont actually exist
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    I've never seen proper warped discs, seen loads of discs with the faces themselves all bumpy, but the discs weren't actually 'warped'.
    Seen any number of cracked discs where people have had drilled discs.
    Drilled discs are the DEVIL.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    I've warped discs in the past...
    Trackday use...then cooled fast...ended up warped, on mounting face to rotor alignment.
    It was suggested that I check the wheel bolt torque then go and get them just as hot by using them hard...and they straightened.
    This was a known issue on the Integra Type-R...so it's possible it's been a factor on other cars.
    In the 2 years I had my ITR I did 15-18 track days and never once warped a disc after getting into the habit of torquing the wheel bolts correctly.
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    Jan 2005
    Colchester, Essex
    147
    ECP want 84.00 for the front wishbones!! Anyone got the correct Audi part no.s
    bouncer--daz Is yours a discounted price from Audi?? Presume if you buy the complete arm it's just a case of wrestling some rusty bolts to swap out the arms and then 4wa. (which suits me TBH).
    Think i'll still get the disc run out checked before i do this though
    Thanks for everyone's input so far.
    Sep 2005
    London
    197
    Quote Originally Posted by Lovegroover
    It's not strictly nessecary, but personally I always fit new nuts & bolts when changing arms.
  28. #27
    Mar 2007
    Gloucestershire
    543
    Thats just from ringing audi in gloucester direct... no discount!
  29. #28
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,435
    Quote Originally Posted by Dave_Bayern
    I knew I should have took a pic of my warped Brembo disks before I threw them away, only did something like 1k miles!
    Sitting on a flat surface, you could actually see 2 ends of the disk 3-4mm away from the surface, and I could feel the brake pedal judder at pretty much any speed from 15mph upwards!!
  30. #29
    Jun 2007
    north yorkshire
    41
    I always thought that to check if u have warpped discs u could jack the car up and rotate wheel if brakes r warpped u feel and here it catching on the pads intermittenly.
    52reg s3 black. Need a pair of them aluminium doors mirros there the dogs.
  31. #30
    Mar 2007
    Gloucestershire
    543
    would depends how badly out they are I guess
  32. #31
    larsmate's Avatar
    Apr 2004
    114
    Quote Originally Posted by Spacecowboy
    http://www.stoptech.com/tech_info/wp...rakedisk.shtml
    Black S3 | MY09 | APR 3.4 Stage 2+ | RNS-E LED | Tints | 19" OEM RS3 Rotors | APR DP | APR HPFP | WALK | Bilstein B14 Coilovers | Lamin-X | Ashtray delete | P3 Gauges integrated boost gauge | BlueVAG VAG-Check |
  33. #32
    Apr 2007
    297
    Ha ha there it is!
  34. #33
    Jan 2005
    Colchester, Essex
    147
    I've got mine booked in for a service on Saturday at local VAG specialist, so will get him to check the bushes and the run-out on discs if necessary. I'll let ya know how i get on.
    Interestingly enough i'm convinced it's the bushes as i've noticed when braking going downhill (i.e. with all the weight on the front end) there's no shake (bushes compressed!). Just a thought?
  35. #34
    Mar 2007
    Gloucestershire
    543
    Ive noticed sum similar symptoms... hopefully guna have my mechanic look at mine this week.
