Sky InsuranceChris Nott
Results 1 to 12 of 12
    Jan 2007
    198
    Part-throttle hesitance/almost a stutttttter.
    AJQ 1.8TQS with a dodgy Chipped-UK remap.
    Not a problem with accelerating, but on a long run and on part-thottle on the M-way, I feel there is a hesitance, which feels almost like a stutter in the system. Full throttle acceleration not a problemo.
    So is it:
    MAF
    Ignition coil
    Fuel filter
    Anything else???
    MY car also has cruise and therefore a drive-by-wire throttle. Any know problems with these?
    Jas
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    Its the dodgy chippedUK Remap.
    <Insert meaningless geeky specs here>
    Jan 2007
    198
    LMFAO
    Now I've just got to sort the wires to the radiator fan and air-con compressor, as they intermittantly stop working
    Ars3.
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    I have a perfectly clean MAF, Clean throttle body, clean filters, new fuel pump and new ignition control module.
    And my car did it too at about 4500rpm. It was the Superchips Remap.
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    Worth checking the MAF, I borrowed Nick's MAF put it in my car and it runs fine! See if you can swap one in for a run and find out! Make sure you buy a Bosch part, no a cheap MAF of fleabay trust me on this I am 60 out of pocket because of it!
    Good luck, dam now everyone has posted! opps ignor me!
    J
    jcb
    Sep 2005
    uk
    4,070
    stock recirc valve?
    mine gave me a little kind of hiccup on cruising/low throttle angles
    worth replacing
    Sep 2005
    London
    197
    Sounds like a map issue to me aswell, transient/over run fuelling.
    Apr 2007
    31
    [quote=Jampublic]Worth checking the MAF, I borrowed Nick's MAF put it in my car and it runs fine! See if you can swap one in for a run and find out! Make sure you buy a Bosch part, no a cheap MAF of fleabay trust me on this I am 60 out of pocket because of it!
    Where can i get a bosch one from as i've had a look on the internet and cant find one or will i need to go to audi?
    Jan 2007
    198
    Got a stock re-circ valve, new 4 months ago - took of a bailey dump valve to replace it.
    Worth getting a newer one? the S3 version? Is it a stronger spring?
    Jas
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    Paul8206 I used a company call CAFCO in Reading, try them on T: 01189 868456 Unsure if the do a mail service! You will need the Bosch part number of course!
    J
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    Hooley have you sorted it yet? Just put new MAF on mine today and car goes like a dream again, no more driving round with the MAF unplugged!
    J
    Jan 2007
    198
    Got other issues to sort first.
    Just had a 300 mile round trip and the temperature went through the roof when I hit traffic on M25.
    Ars3
    Don't think the fan is cutting in.
    Also need to check the air-con compressor wiring as it's stopped working again. Intermittent fault.
    Double ars3.
    Jason
