Thread: dump valves ?
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    dump valves ?
    Hi there just a quick question what advantages would i get from fitting a dump valve to my s3 and where can i find a recirculating one that isnt a blow off valve,,,,the ones that sound like a pigeon on steriods,lol,,cheers
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    The factory plastic DV's are prone to splitting especially on remapped cars, definately worth upgrading to an alloy one.
    http://www.forgemotorsport.co.uk/con...oduct=FMCL007P
    or
    http://www.jabbasport.com/product_fu...p?ProductID=22
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Fitting an aftermarket dump valve will not get you extra horsepower by itself, much like an intercooler. It helps you get the most power out of the turbo by holding boost longer than the original one.
    If your car is remapped then I would recommend you get one as the OEM DV is prone to splitting under increased pressure. If your DV is going you will hear a distinctive honking noise when you lift off the throttle.
    I've got a Forge 007 DV and it is near silent, I don't want to advertise to the world that I have a turbo (even if it is the crappy KO3) unlike the garish Jap cars I see around these parts.
    Slipping at 3.5Krpm
    Sep 2006
    Berkshire
    1,951
    AAAAAAAAAAAAAAAAARRRRRGHHH!
    Diverter Valve
    Thank You
    <Insert meaningless geeky specs here>
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Dave, I usually call it a diverter valve but most people do not know what it is, so to be safe I call it a dump valve.
