Chris NottAH Fabrications
    May 2003
    Ipswich/Glossop
    52
    Turbo Intake Pipes
    On some of the threads I've read some of the A3 owners have commented on their new turbo intake pipes. From this I presume they are talking about a larger diameter intake to the turbo. Is this a modification available for the S3 or does this model already possess a larger diameter intake? [img]/ubbthreads/images/graemlins/confused.gif[/img]
    GBH
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Re: Turbo Intake Pipes
    The S3 doesn't have a metal turbo inlet pipe, despite a certain company advertising that their aftermarket pipe is suitable!
    The hose from the MAF goes directly onto the inlet to the compressor of the turbo...with a jubilee clip either end...no metal pipe involved.
    Dec 2003
    6
    I know Ottinger do an aluminium turbo intake pipe costs about 380 incl vat. No sure how good it is or how easy it is to fit but Oettinger have a good rep. I think you can get this through RSD.
    Dec 2003
    6
    I know Oettinger do an aluminium turbo intake pipe costs about 380 incl vat. No sure how good it is or how easy it is to fit but Oettinger have a good rep. I think you can get this through RSD.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Isn't the Oettinger pipe a replacement for the rubber hose from MAF to turbo?
    I believe so...rather than a replacement turbo inlet metal pipe thet a hose then goes onto.
    The Oettinger piece is probably very nice, but why spend that kind of cash when Forge do a Samco hose for around 100 that does the same job?
