Monster MotorsportChris Nott
    Sam-K's Avatar
    Has a throbbing red german.
    May 2007
    Near Aylesbury (home) Stafford (uni)
    473
    Headunit wiring help please !
    i have done a search ,
    but can't find what i'm after.. basically.
    i have a 97 1.6 sport a3, and have changed the headunit to an alpine one , but the way i have wired it without the correct harness leaves the rear speakers not working, so i would like to know what harness i need for my car , it's not a bose system or anything, but has one of those funny little subs hidden in the rear passenger side bit
    help would be well appreiciated!!
    Jun 2004
    Surrey
    595
    Connector I pins 1-6 connected OK I assume.
    Sam-K's Avatar
    May 2007
    473
    my connector (alpine end) only has four pins.. so i need to know what harness i need really..
    Jun 2003
    World of my own
    9,813
    There are 2 adapters, one uses the RCA's of the Alpine to feed the rear/sub amp, the other uses the rear speaker output of the Alpine via a hi-lo converter.
    The RCA adapter is technically the best one to use, but some HU's cause the rear amp to "pop" when changing CD tracks, which is a "feature" of the stupid Audi amp design. Autoleads Part No. PC9-404
    The speaker input adapter won't induce any popping but is technically less clean as the signal is amplified at the HU then reduced back down to pre-out level by the adapter then re-amplified by the Audi amp. Autoleads Part No. PC9-401
    The popping issue seems to depend on the pre-out voltage of the HU, s if it's a 4v+ then I'd recommend using the speaker input adapter.
    The best solution is to actually rewire the rear spekers directly to the HU and cut out the 2 x 20w rear amp as it'll be completely ovepowered by the Alpine front amp driving the fronts. You can then use the RCA adapter connected to the sub out of the HU Iif it has one) to just drive the tupperware sub and also give you some control of the sub independent of the rears.
    You can get the adapters from big Halfords or online:
    http://www.bluespot.co.uk/install/show_model.asp?id=15
