Chris NottSky Insurance
Results 1 to 9 of 9
    Apr 2007
    Hazlemere, South Bucks
    63
    Dashboard warning light???
    A warning light has appeared within the 'speedo dial' on my S3. It is a picture of an engine, but I can't find any details in the owners manual about it.
    I think it came on after I pulled away hard with the ESP turned off - l felt a little bit of wheelspin and then it gripped as normal.
    What am l likely to have done and how do l fix it?
    Jan 2007
    29
    A colleague of mine had the same problem on his V6 Golf 4-Motion, I think it turned out to be a sensor of some sort, I'll ask him tommorow and let you know for sure.
    Apr 2007
    63
    Thanks - l suspect l may have 'upset' a sensor. Ooooops !
    petewon's Avatar
    Dec 2004
    Newcastle
    514
    thats the CEL (engine managment) light, could be anything. Best off getting someone to scan it with VAG.COM.
    Pete
    _______________________
    8P A3 2.0 FSI Sport, Leather/Alcantara, Bose, Xenons.
    Apr 2007
    63
    Do I have to go to an Audi stealer to get that done or will a normal garage/independent be able to scan it?
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,897
    indy vag garage should be able,just phone around
    Jan 2007
    29
    Hiya,
    Found out from my mate on his 4-motion it through out the brake light switch, sounds odd but thats what it was when examined by VW. (he said check your brake lights are working)
    Hope this helps
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    How can people not know what an Engine Management Light is?
    Anyway, it could be a multitude of things. It can be triggered by any error and only a scan would be able to tell you, for certain, what is going on. Otherwise it's just trial and error.
    Jampublic's Avatar
    Taking it easy..
    Jul 2006
    Reading, SE
    972
    Cycle Si did you get it sorted? A garage could charge you as much a £50 to plug in and check faults, a stealer could charge you a load more!
    J
