JMB RetrofitsBadger5
Results 1 to 7 of 7
    Apr 2007
    Wirral
    196
    Best launching technique
    Whats the best way to launch an a3 1.8t off the line to get the fastest acceleration?
    I have tried holding it around 3k revs and launchin wit the esp on, but it seems to bog down slightly and revs drop when you let go of the clutch, but soon as the turbo kicks in it pulls nicely.
    I tried my way and got a 0-60 of around 7 secs, the car has a chipped uk map and a cat back erhaust. Is this a realistic time?
    Do you guys launch with the esp off or on.
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    at pod in my S3 i launch at 5500rpm with ESP off i try not to do this too much!
    if yours is front wheel drive then keep it under 4500rpm or it'll just wheelspin.
    bogging means not enough revs or tooslow inputting right foot down when releasing clutch!
    hope that helps!
    S3 - Gone but not forgotten!
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,900
    I launched at 6k at brunters but only did 14.6,what would launching in second be like? has anyone done it?
    Avon raceway is meant to be empty on their RWYB so might go and try different methods.
    Emmo get some practice mate,you'll get to know your limits as well
    Apr 2007
    Wirral
    196
    ive been too slow in putting on the gas when realeasing the clutch as you said sitrials. just being a bit careful with the clutch.
    what point do you shift at do you let it go til just before the redline?
    I'm using to revving to the redline as my last car was a civic vtec, and it used to pull all the way to the redline.
    But the civic never had the torque from 2k as the audi does.
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    In the wet with ESP off i can spin the rear wheels. Usually i launch around 4k but you gotta watch out for kangerooing
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,900
    ESP,ICE,A/C all have off before you even get on the line
    the pod sunday GTI summer festival would be a good measure
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    i still want to go up against an S3 all i have raced so far was S4 (standard), and an 8P A3 2.0T superchip remap also.
    they were pretty close, but iwant to go up against a remapped S3 will try a do another day again soon probly be at shakespear raceway little bit more quiet!
